M Jarve
Audio Geek and NGE Freak
It's been years since I've done one of my classic Inside and Out pictorial/commentaries. A quick search shows the last one was all the way back in 2011. So, I suppose it's about time for one, since I have a unit I think is interesting to share.
The unlikely and (perhaps) controversial history of the CC-2 by Audionics of Oregon (or Audionics, or Audio of Oregon) is recounted elsewhere on the internet, so I will not do so here. But I will mention that it was one of the first US made power amplifiers designed using the precepts of Dr. Matti Otala. In the 1970's, Dr. Otala had proposed that high that a "new" form of distortion, transient inter-modulation distortion (TIM) was more harmful to a musical signal than the much more well known total harmonic distortion (THD). At the time, one of the main methods of reducing THD was incompatible with reducing TIM; he seemed to suggest that sacrificing by accepting a bit lower THD rating, an amp designer could reduce IMD, and the amp would output a signal more faithful to the musical signal, and the amplifier would be more stable over all. Manufacturers in Europe and Japan (notably Electrocompaniet in Norway and harman/kardon (under the ownership of Shirasuna) in Japan) already released amps/receivers, etc using Dr. Otala's philosophy.
The CC-2 is a medium power amp, capable of 70-watts per channel into 8-ohms. The amp can nearly "double-down" outputting 120WPC @ 4-ohms and 170WPC @2-ohms. Bridged to mono, it can output >200-watts @ 8-ohms. It is a very dynamic amplifier that provides a sense of immediacy that few others can. Although not a DC design (there is an input coupling cap), it suffers no restriction of the low-end, nor is there any softness to the high-end.
Physically, the amp is quite compact. While maintaining a pro-standard 19-inch width (complete with rack-mount holes and handles), it's only 2-rack units tall, and less than 8-inches deep. It's dimensions belie its mass, though, as a good amount of the internal volume is taken up by a very large split-core power transformer (~600-650VA by quick calculation). Power is rectified by a large, quasi-heat sinked full-wave bridge rectifier, and smoothed by a pair of 15,000uFd caps. There are no large heat sinks, as the whole chassis and covers act as the heat sink; being moderately powered, and not biased highly into class A, it doesn't need large heat sinks.
To either side of the power supply are the amplifier boards themselves. Output devices are (now) unobtainable Motorola 2N5630 and 2N6030 (one pair each per channel). Bias test points, as well as bias and DC offset adjustments are conveniently located near the output transistors.
One nod to the audiophile community of the time is the then uncommon gold-plated input jacks. And like many many purest amps, there is no turn-on delay or output relay; protection is provided by a 3-amp fuse and nothing else.
