periclimenes
Just for fun... I actually prefer amp on top because the volume is easier to access (it's on a low table). Then again, if I had it on a high table, I'd want it on bottom!
I was under that impression as well, but whenever I see a photo of somebody's setup, the amp tends to be on the bottom (maybe because receiver design has dial on top, knobs on bottom?).It's better to have the amp on top as amplifiers produce a lot of heat.
Tuners hardly generate any heat. If you have it the other way around, the heat produced by the amplifier would not be good for the tuner.
Most brochures show the tuner on top of the amp, which seems to me like a way to reduce the amount of airflow through the amps heatsinks.
Lee.
Think about watch advertisements, what time is it always?
Tuner on top shelf means you wont have the FM antenna/wiring crossing over/near any of the other IC/speaker/power cables or such.
