Yes, is from the auction site. Here are some photos.
The two plugs seem to have different number. I almost seem to ready 100/1 and 100/2.
Also, I'm not 100% sure of the tube lineup. I found the amp with 2x KT66 inside, and 2x 6SN7 in the front.
No rectifier, I'm not sure if I should use a 5U4 or else.
No multi filter cap, I am planning to use a 30+20+20+20uf 550v. I would measure the voltage at the 4 holes of the multi filter cap socket and put 30uf on the one with higher voltage. I could alternatively use an 80+40+20+20uf 550v, but I'm not sure if 80uf is too much for a 5U4. I could also use a 5R4GYZ as I have many laying around. Again, not sure if it would be a good idea.
On the front, the schematic you mentioned uses 1x 6SL7 and 1x 6SN7. I'm not sure why mine came with 2x 6SN7. Maybe the previous owner replaced the 6SL7 and used the wrong tube to replace it?
I already removed all the bumble bee, they all tested leaking. And replaced the 100uf gray cap with a 100uf 100v.
Waiting on the soviet PIO to arrive to replace the bumble bee.
