MooTheFish
New Member
Hi all. New member here although havelurked the forums for quite some time. Usually I've been able to find whatever I was looking for but I'm pretty stumped with this one, so any help would be appreciated.
WALL OF TEXT INCOMING:
I recently acquired an old Rank Arena RA-402 reciever/amplifier for free, and while it might not be the best of old audio gear, I love it's looks and to me at least it has a nice punchy sound to it. It worked fine but had a fair amount of noise in the output and the right channel was giving me some issues.
Given the age of it I decided to go ahead and recap the power supply, amplifier and front panel, which I have done (with the exception of two caps on the left channel of the amp board, still waiting for the replacements to arrive). The recap certainly helped, but there's still a noticeable amount of noise across both channels regardless of where the volume and balance controls are set. Changing inputs makes no difference, nor does using the other set of speaker outputs.
If that was the only issues I could live with it, but the big problem is with the right channel. After switching the unit on and using it for a bit, a crackly, hissy noise comes through the right channel, gradually getting louder, until there's a loud POP through the speaker and it settles back down again. This process will repeat itself. But if I quickly power the unit off and back on again the noise clears up completely and it will continue to work fine for quite some time before the noise returns.
My current theory is that something is producing more noise as it heats up and then cuts out with the pop sound. What's strange to me is that the unit will still pass a signal throughout this process, and I have no idea why quickly powering it off and on would correct it. I've tried swapping the large resistors next to the main output transistors between each channel, as one of them had been replaced. But the issue remained on the right channel.
I've also tested all the other resistors and done a basic check of the transistors on the amp board and everything checks out ok, so I really don't know what to do next. Knowing me, I've probably missed something obvious
Any help is appreciated and sorry for the wall of text lol.
