Hello everyone.
First of all I would like to apologize for bad English, I am using the Google Translate tool.
I'm Brazilian and new to the Reel to Rell world. I bought a used Akai GX-625 and want to leave the same effect just like the day it left the factory. When I received the same, I realized that the work will be arduous ... it was quite dirty and with several capacitors and bad transistors on the amplifier board, but fortunately this is all original, all the seals of the heads of reproduction / recording intact, I believe that never has been previously opened. Initially I did a nice cleaning and lubrication on the 3 motors and by all the paths where the tape goes.
After everything clean, I made the purchase on Ebay of this Kit here:
https://www.ebay.com/itm/PREMIUM-Re...07?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872. m2749.l2649
My idea was initially to get this kit to only then start working on it, but anxiety did not allow me ... so I decided to use the BC 549C and general purpose electrolytic capacitors instead of the C458 transistors. I made the exchange of all the electrolytic capacitors that I will receive in the future (the seller sent a PDF with the position of the capacitors and the transisotres that need to be changed) and after the exchange the Akai came back to life!
Well, it is my experience in repairing a Reel to Reel and I am honest in saying that I do not have much experience in repairing audio equipment, I am more focused on repairing video equipment. I imagine I have everything I need in instrumentation for the correct repair (oscilloscope, audio analyzer, audio generator, etc).
Returning to the Akai, when connecting the audio generator via line inputs, at a frequency of 1Khz and 0dB and turning the key to Source it is possible to verify that the reading in the Vu is unbalanced, one channel is -1.5dB in relation to the other . Even so I did a recording test and it is possible to perceive a slight loss of treble in relation to the source signal (using music as source) and a small imbalance between the recording levels of both channels using the audio generator as signal source .
I wonder if it is possible to try to start fixing these problems without an alignment tape or if everything is wasted without it?
Thank you in advance.
