Is anyone here running an amplifier using their receiver as a preamp?
Discussion in 'General Audio Discussion' started by Harvestor, Jun 28, 2018.
  1. Harvestor
    Harvestor Super Member
    I haven't run across any discussions here where people are using a receiver bypassing it's internal amp and using an external amplifier..
    I'm curious how many or how few here on the forums are doing this?
    There are many good receivers that offer the ability to do this like the Technics SA 700-800 & 1000 and many Sansui, Pioneers etc..
    So I'm curious what what people are running and what their experiences are?
  2. NeedForSpeed
    NeedForSpeed Living In The Past Subscriber
    26,616
    SF Bay Area
  3. macyjrm
    macyjrm AK Subscriber Subscriber
    1,297
    Mississippi
    I do it almost daily and find it no different from having a separate, dedicated preamp except of course for the receiver’s built in tuner.
  4. StimpyWan
    4,396
    Blue Ridge Mountains!
    I've used my Yamaha RX-A3030 AVR with external amps. Never had a problem with the set up. It sounds fine.
  5. Dave_1962
    Dave_1962 Lunatic Member
    20,351
    Ontario, Canada
    I'm running a Sansui BA-2000 using a Marantz 1150D integrated amp as a pre.
  6. 81spirit
    81spirit Super Member
    1,392
    Shiloh, Tennessee
    My Sansui G-3500 had a channel out- converted it for use as a pre - sounds great.
  7. motorstereo
    10,466
    Connecticut
    I started out doing this and it was fun comparing the preamp sections of different units. Then the upgrade bug bit for a standalone preamp and my rca jumpers have sat in the drawer ever since.
    satellite likes this.
  8. bimasta
    bimasta Super Member
    3,012
    Tried it only two days ago and still using it, so impressions are fresh. Of course results will depend on the individual preamp section and power amp used. In the last 6 months I've had an appalling failure rate with my pre and power amps, mostly through age, a couple my own fault (oh the guilt!). I turned to a receiver as a stopgap till I have some repairs done (most are beyond my skills). I had a Nakamichi receiver — post-Stasis and AV, so not even a primo Nak — and it surprised me. It's very good. Tuner is very-very good. Phono stage was only capable so I used a standalone through the tape loop. Much better.
    My speakers needed more power. I had one really good power amp left, Museatex, and tried it. I liked the Nak's power section, but this was a total transformation, way beyond "very good". The repairs are no longer urgent, I can happily live with this combo for awhile, and the convenience is a treat.
  9. Roboturner91
    Roboturner91 AK Subscriber Subscriber
    1,217
    SW Indiana
    I've done it lots. I have a Yamaha CA-810 feeding into a couple of big Audiosource amps to some hideous PA speakers that I use for backyard parties and such.
    In the house I have a B&K ST2140 that I've used with a couple different receivers and it sounded good, but I didn't need all the extra power for my current speakers.
  10. sKiZo
    Yup ... I've been doing that for years and years here with various Sansui receivers using a tape loop. Standard cabling if you're just feeding the raw signal to the amp, but in my case, I also have a bunch of post processing going on. For that, I need to complete the loop back to the receiver.
    Originally used a "Y" adapter to add the amp to the loop. Much prefer the hard version to the standard cable. This is the setup for my SS amp.
    Latest external amp was a custom build tuber, and I added the "Y" to the back panel. Both sets of jacks are joined internally. Kinda like belly buttons - Think of it as an "innie" vs an "outie" ...
    EngineerNate and satellite like this.
  11. awillia6
    awillia6 Super Member
    1,398
    Yup, Denon AVR3808 into a Crestron CNAMPX-7X200 (ATI-built 7-channel 200wpc SS amp) for 7.1 home theater and 2-channel music (using different speakers and receiver-resident room correction setups).
  12. Kreshna
    Kreshna ...but I have to know.
    1,034
    Indonesia
    westend likes this.
  13. awillia6
    1,398
    What're all those digital inputs doing empty...?
  14. satellite
    satellite AK Subscriber Subscriber
    1,572
    Boise Idaho
    Still saving money for a proper preamp for my MC 2105, so I'm currently using the pre from my Sansui 5000X.
    Have also had it hooked it up to my Marantz 2230 and Heathkit AR-1500.
  15. mhjmhjones
    mhjmhjones AK Subscriber Subscriber
    318
    Delaware, USA
    I am. My Pioneer Elite VSX-81TXV has a built-in second zone RCA outs that I run to another Pioneer A-35R amp. I can run different sources on both zones and can control the volume of the speakers on the second zone with the receiver. I have four pairs of speakers running off the system, as well as a sub and center/L/R in the main room.
  16. EngineerNate
    3,479
    Any details on your processing setup?
  17. musichal
    11,770
    Norman OK
    I have done so many times in the past and found the sound adequate. JK. Sounded good, but I didn't like not using the amp in the receiver, and had no use for the amp section for very long (no surround, no Zone 2). So I went with the pre-tuner + amp approach or entire separates. I no longer use separates, but am doing the pre-tuner-DAC + amp thing in the bedroom and an integrated amp in the den.
    Oops, I do have a modest separates system in the guest room that no one ever uses comprising a NuForce pre, Pro-Ject tuner and Emotiva amp with B6 and a Polk sw. Good little system, and I mean no one. I'd sell it but it's good for back-up if something quits in the others.
  18. sKiZo
    I assUme now you're sorry you asked? <G>
    musichal likes this.
  19. goodolpg
    goodolpg Just an old fart trying to help.
    I did briefly. Used an MCS 3125 as a preamp and a Rotel RB-990BX for the amp.
    Worked just fine, but ended up buying a couple actual preamps instead. NAD 1700 and Carver CT-17, liked the fact they both come with remotes.
    This was a few years ago, when after 35 or more years with receivers only I went to separates.
  20. RickeyM
    RickeyM Super Member
    2,037
    Baltimore, Maryland
    Count me in. Longtime Sony ES fan, but the STR-DA-4ES's onboard amp just didn't have the juice necessary to do my Maggies justice. The Sony functions very well as a preamp. Great SQ, really good phono section and the ability to control all of the receivers functions by remote control. The amps I've used have been a big Pioneer, a BGW and now an Emotiva.
