dogwan
Dogwan
Years ago I rebuilt my Dynaco PAS into the Norman Koren Spiced PAS.
http://www.normankoren.com/Audio/Spice_preamp.html
At the time I was lucky enough to have a nice stash of vintage 12ax7's. Mostly Telefunken's and Siemens from Germany. I really love this pre. The sound is killer.
Now at one point I thought about I would re-tube with modern issue Mullards and save my vintage ones. That was a bust as I had 2 out of 6 tubes fail within a couple days. They were returned and I happily returned to the Tele's.
Flash forward to this year when I bought a used ARC SP-16 that came with good Electro-Harmonix in the line stage, and Sovtek LPS in the phono stage. I was using the ARC for a while and decided to try the Tele's in it. SO, I moved the EH's and Sovtek's to the Spiced PAS. I used the PAS a couple times in another set up and all was fine when it was stored later. Then I decided to switch all the tubes back and when I tried to fire up the ARC with the EH's and Sovtek's I had no sound. Problem was traced to one Sovtek that tested completely dead on my tube tester. Nada, nothing, zip. WOuldn't even register on the emissions test.
So, this has me thinking that maybe the B+ in the PAS is killing modern tubes. The B+ is supposed to be 320v on the CF of the linestage (TU6) , and 280v on the CF of the phono stage (TU5). I actually did drop it down a touch and it actually measures 308v and 275v respectively.
Is this to high for modern issue tubes? The Tele's and Siemens just keep happily trucking along. Am I going to be stuck using vintage tubes for the life of the unit?
