Is the Shure Me95ed cart a good match for Dual 1019?
Discussion in 'Turntables' started by dpg3, Nov 10, 2018.
  1. dpg3
    dpg3 Well-Known Member
    686
    I'm getting a Dual 1019 repaired/restored, it has an old ceramic cart on it that I want to replace with a Shure Me95ed cart. Is this a good match for the 1019?
  2. jcamero
    jcamero Who are you people anyway? Subscriber
    4,209
    The Dairy State
    Shure and Dual are a good match. In fact, I am rehabbing a 1019, and will be using the same cartridge.
    dpg3 likes this.
  3. dpg3
    686
    Thanks that's good to know!!
  4. jcamero
    4,209
    The Dairy State
    Probably should of mentioned since the 1019 is a "stacker" table, you will need to shim the cartridge to level the tone arm. I have not got that far, but shims are available on ebay, or you can make your own.
  5. Zvezda
    Zvezda AK Subscriber Subscriber
    293
    Des Moines, IA
    I've calculated the effective mass of the 1019 tonearm to be about 11 grams with the aftermarket headshell I'm using. Not sure how different the mass of the original headshell is. I'm led to believe that the compliance of the M95ED is around 25-30 which should give a resonance frequency of around 7hz. That's generally considered about as low as you want to go before you run into footfall/warp issues. All of that said, these turntables were often sold with Shures when they were new, so it must have worked well.
    dpg3 likes this.
  6. Zvezda
    293
    Des Moines, IA
    I bought one of these shims and found that it was far too thick and too aggressive of an adjustment. Both cartridges I tried with it ended up tail-down. I used a little shim made from a credit card wedged under the rear of the cartridge and it worked great.
    illinoisteve and dpg3 like this.
  7. jcamero
    4,209
    The Dairy State
    Good to know, I'm not ready to mount my cartridge.
    dpg3 likes this.
  8. Decibel_116
    Decibel_116 AK Subscriber
    2,020
    Madison, Alabama, USA
    One of my early exposures to HiFi back in the late '70s included a similar Dual with an M95ED through a Marantz 4270 with excellent results! It made quite the impression on me as I still recall the clarity and imaging like nothing I had ever experienced before. I think you will like it.
    dpg3 likes this.
  9. dpg3
    686
    Thanks everyone for your replies, I'm going to use the Shure on the 1019!!
    illinoisteve likes this.
  10. likebike23
    likebike23 Super Member
    1,468
    Western MA
    Looking forward to your impressions on the combo. I have that cart and that table and haven't tried them out together.
    dpg3 likes this.
  11. MCM_Fan
    MCM_Fan AK Subscriber
    2,820
    Oregon
    I can't tell what stylus is on your Shure cartridge, but NOS Shure Ne95ED are still available at very reasonable prices. I have a Realistic R47XT, that is basically an OEM version of the Me95ED. This is a light tracking 0.2 x 0.7 mil elliptical. My R47XT came with a LAB 440 turntable I bought a few years go, but was missing the stylus. I picked up an Ne95ED from LPTunes:
    Perfect fit and sounds great.
    dpg3 likes this.
  12. dpg3
    686
    I'm bringing the 1019 in to get restored Monday and the Shure cart mounted, let you know when I get it back.
  13. dpg3
    686
    Stylus is a Shure 70 B, I have it on a Dual CS 503-1 and it sounded really great. Stylus had little to no hours on it.
  14. MCM_Fan
    2,820
    Oregon
    That's a 0.6 mil conical with a recommended VTF of 1.5 - 3g. It's a good stylus (most genuine Shures are), but a lighter tracking elliptical might be a better match for your tonearm and cartridge.
    dpg3 likes this.
  15. dpg3
    686
    OK thanks.
  16. seamas
    seamas Active Member
    171
    n.w.arkansas
    I also have the r47xt with the ne95ed stylus on my dual 1229.In my opinion,what a deal as the used realistic shure r25xt and r47xt can be found inexpensively and the NOS Shure ne95ed can be found still for less than 60 bux.
    MCM_Fan and dpg3 like this.
  17. 911s55
    911s55 AK Subscriber Subscriber
    562
    Puget Sound
    That Shure ne95ed made my 97xe listenable with high end the original stylus was masking, perfect fit as well.
    Another compromise to getting the vertical tracking/stylus rake angle closer to accurate is to use a thicker platter mat or add one on the existing. That's what I've done with my Elac Miracord 50H, also an auto stacking table.
    dpg3 likes this.
  18. dpg3
    686
    I think I'll try what I have at the moment and see what that sounds like but I appreciate the suggestion!!
  19. dpg3
    686
    OK thanks good to know.
  20. dpg3
    686
    I sent the Dual 1019 to a tech and it was beyond repair.
