Is there a fix for pioneer push switches?
Discussion in 'Pioneer Audio' started by dlanor, Jun 20, 2010.
  1. dlanor
    dlanor New Member
    23
    I have an otherwise full functioning Pioneer sx-3600 receiver. The push switches do not stay in the "in" position. I have searched the forums w/o finding any info on how to repair or bypass the faulty spring detente. Help Please.
  2. merrylander
    merrylander AK Member
    20,707
    Glenwood, MD 21738
    Probably the same Alps brand switches Yamaha uses, only cure I have found to date is parts from an organ donor.
  3. kcollins4
    kcollins4 Rocking somewhere
    5,731
    Katy, TX
    I can't give you a specific answer, but there are 110 results for "Pioneer switch" on the auction site. There probably is a new replacement available also, if you do some research on the physical layout of the switch..
  4. markthefixer
    21,009
    Bensenville,Illinois
    There is a common bar that links all 4 (am,fm,phono,aux) under/in the metal frame that is spring loaded.
    Either the spring has come loose (unlikely) or the bar itself is binding (junk or petrified grease) and some faderlube shot through the whole channel may free it up.
    Has this unit been in your possession long, or have you just acquired somebody else's handiwork?
    The bar is vulnerable to binding anywhere over it's length, while it has less than 1/4 inch of needed motion. It is also vulnerable to cumulative friction over it's entire length, there may not be a lot of friction from dried grease at one point, but add that up the entire length, and it's enough.
    edit:
    This push & hold one of multiple switches part of the mechanism is NOT the same fragile part of the mechanism that is a single push on push off switch. I JUST checked!! It IS most likely a junk/grease problem.
    It is possible that one of the switches has stuck partially down as well, so deoxit /lubricate them ALL and check each for full range of motion and operating return springs.
  5. Pickoid
    Pickoid Tired
    420
    Little Rock, AR
    Curse those blasted switches! I have a Yamaha A-960II amp with a bad "main direct" switch. I got a switch from a parts unit and swapped it in. It was good for about 6 cycles of the switch when it broke, too. :tears: Oh well...
  6. shimniok
    shimniok Super Member
    3,663
    Centennial, CO
    Not sure if these are the same as the accursed push-button switches on the HK680i (and similar) but I did find what looked like new direct replacements awhile back... ?
  7. dlanor
    dlanor New Member
    23
    Thanks for the reply but these are the single switches which activate A or B speaker, FM muting etc.
  8. shimniok
    3,663
    Centennial, CO
  9. markthefixer
    21,009
    Have you pulled the faceplate to see if it was causing problems? ALL of them is pretty suspicious.
  10. dlanor
    dlanor New Member
    23
    Pulled face plate. No joy.
    Apparently the stop inside these push activated switches breaks off inside the switch. Someone suggested just removing the switch return spring(a small coil spring on the pushbutton shaft). Has anyone done this without disassembling the front of the receiver completely? This switch is accessible with just the cover off.
