    Dismiss Notice
Is this a thing?
Discussion in 'Digital Sources' started by trucha, Oct 26, 2017.
  1. trucha
    trucha New Member
    31
    I have an old vintage receiver and I'd like to hook up both a CD player and my phone and I pods. The receiver only has one aux setting so I have to keep switching between rca cables and the rca to 3.5 jack for the phone. It is a pita so my old CD player just sits there unused. Is there any CD players out there that allow a digital source in and then out to the receiver? Or any other way to do this?
  2. 4-2-7
    28,982
    San Francisco Peninsula
    I will help greatly to list your equipment and models and we can come up with a good way to hook it all up.
  3. trucha
    trucha New Member
    31
    Hitachi 903
  4. blue72
    blue72 Active Member
    114
    Southern Utah
    You should be able to use the two tape inputs on the back of the Hitachi. Hook up your RCA cables to the "Play" side and away you go.
  5. drew_t
    drew_t AK Subscriber Subscriber
    702
    Easiest thing to do is probably get an AV switchbox like this https://www.amazon.com/dp/B00KXVBB3Q/ , ignore the video part, and use mini jack to RCA plug patch cords for phone and pod.. If you look around a lot and/or get lucky, you might be able to find one that is meant just for audio, and maybe will have mini jack connections in addition to the RCAs.
    EDIT: the post above came in while I was writing this.
  6. 4-2-7
    28,982
    You have three inputs you can use
    AUX
    Tape 1 (Play)
    Tape 2 (Play)
    I will also say you could use the Adaptor Input (In) next to Tape 2
  7. trucha
    trucha New Member
    31
    Ok I didn't realize I could use the tape inputs. Is there a way to route through the CD player to take advantage of the dac in there ?
  8. botrytis
    29,377
    PODUNC USA......
    Depends on the CD player - it actually needs to be a newer Universal player to do that - like an Oppo.
  9. Mitkraft
    Mitkraft Super Member
    2,768
    Houston
    Most CD players do not function as an outboard DAC since they would need to have a digital in which very few do. HOWEVER, in order for you to even utilize one that did, you would have to feed it DIGITAL signal from your phone/ipod. You might already be aware, but just in case you aren't, if you are using a headphone jack out then your ipod/iphone has already converted the signal to analog so no further DAC is needed/desired.
  10. trucha
    trucha New Member
    31
    OK, so this is a thing then. Great! So, which cd players would let me do this? I guess cheaper the better and how do I run the digital signal out from my iphone and ipod? And if I don't run my source through the cd player is this digital out better than running it out of the headphone jack? If so how would I go about hooking that up.
  11. trucha
    trucha New Member
    31
    Would this work....???
    Best For CD to USB Copy - Sony CDP-CE500 5-Disc CD Changer
    Sony's CDP-CE500 is an affordable 5-Disc CD changer that does the job. Featuring CD, CD-R CD-RW, and MP3-CD playback utilizing 1-bit DA converters, the sound quality is great for a budget player.
    This unit also includes both analog and digital optical outputs, USB port, and can be controlled directly or from the provided remote control. The USB port provides the added flexibility to either play back music files (AAC, MP3, WMA) stored on a USB or other compatible USB storage device.
    One additional added perk is that the included USB port can also be used to copy the music from your Music CDs to a USB flash drive.
  12. gvl
    gvl Super Member
    1,044
    That Sony CDC isn't a thing as despite it having a USB port it cannot function as a DAC. CDPs that can function as DACs tend to be expensive. If your CDP has a digital output better get a decent stand-alone DAC with both SPDIF and USB inputs, you can then connect both your CDP and iPhone to it digitally sending DAC's analog output to the receiver. You won't be able to have both the iPhone and iPod connected at the same time (DACs usually have a single USB input). It should improve sound from your CDP as well.
  13. E.Auer
    E.Auer Super Member
    2,024
    Lobster Pot
    Keep the CD player plugged in, Get a CCA that you plug in to one of the tape "play" inputs and stream to the CCA over Wi-Fi from your I-devices.
    CCA
    Eric
    Chromecast Audio
    ldatlof likes this.
