Is This Anything Special?
Discussion in 'Turntables' started by JJCalvillo, Jan 2, 2019.
  1. JJCalvillo
    JJCalvillo AK Subscriber Subscriber
    344
    Portlandia
  2. Balifly
    Balifly Listening Subscriber
    20,892
    Vancouver, B.C., Canada
    Looks like a Pioneer PL-41xx.
    To their owners, they may be special. :)
    Vinylmasters and JJCalvillo like this.
  3. Montycat
    Montycat AK Subscriber Subscriber
    17,801
    Vancouver
    With TLC it could be.
  4. JJCalvillo
    344
    Portlandia
    You’re right, thank you. Looks like a project.
    Yeah, looks like plenty of work.
  5. Nat
    Nat AK Subscriber Subscriber
    13,140
    Actually, it's quite a nice table. It will need some work, and if it is one with the auto return, you may be driven bananas trying to get it to work. A bad thrust bearing is a common issue, but not difficult to fix. The belt has to be the correct thickness if it is to run at the correct speed.
    JJCalvillo likes this.
  6. JJCalvillo
    344
    Portlandia
    Going nuts waiting until “the appointed hour” to look at this, as well as a 2015B.
  7. JJCalvillo
    344
    Portlandia
    Table raises another question. How do you determine an older table is at the correct speed? To a degree you can hear it, but I’d imagine there’s a more accurate way.
  8. Balifly
    20,892
    You can down load and print a strobe disc:
    https://www.vinylengine.com/strobe-discs.shtml
    Or buy one on Ebay - look for "Strobe disc". :)
    JJCalvillo and oldman54 like this.
  9. JJCalvillo
    344
    Portlandia
    Should I drop $30 on this table?
  10. revox-b77
    revox-b77 AK Subscriber Subscriber
    3,128
    Fingerlakes, NY
    I would.
  11. boreas
    boreas "If it sounds good, it IS good." E.K.E.
    15,695
    Sonoma County, CA
    I would. It's worth a lot more than that. They have a pretty big following. I parted out a basket case on eBay for about $350 (and I still have the platter).
    Regarding @Nat's concern about the auto return mechanism, the PL-41 is manual so no auto return to worry about.
    Grbluen and JJCalvillo like this.
  12. JJCalvillo
    344
    Portlandia
    Muchas gracias, boreas.
  13. boreas
    15,695
    Sonoma County, CA
    ¡Ni lo menciones!
  14. JJCalvillo
    344
    Portlandia
    The PL - 41 is now in the spa.
  15. AdamAnt316
    AdamAnt316 Collector of heavy things Subscriber
    2,542
    MA
    Very nice! :thumbsup: Should clean up nicely.
    With regards to you question on checking the speed on a turntable, a strobe disc as mentioned above is the easiest way to do it. However, you'll need to make sure you're using a proper light source. A CFL or LED bulb won't cut it, as they generally 'strobe' at the wrong frequency. Your best bet will be to get a neon bulb; failing that, an old-fashioned incandescent bulb should do the trick. I have a neon panel indicator lamp along the lines of these with a line cord rigged up to it which I use for strobe discs, though I have a bulb along the lines of this which I may put to use for the purpose.
    -Adam
  16. JJCalvillo
    344
    Portlandia
    Thanks Adam. Already downloaded the strobe disc from Vinyl Engine. Seller said it needed a belt, but when I opened it up the belt was off. So I want to reinstall that and give it a spin to see what I get. Looking into the install procedure now. Looks to be in pretty good shape except for missing a dust cover and rotted feet. Still have to give it a test drive though.
  17. JJCalvillo
    344
    Portlandia
    So it's playing but sounding a little slow. Have to order a new belt, and the cartridge is sort of an unknown factor. Not sure about the speed consistency, haven't put the strobe disc on yet. Have to get the correct oil and hit the joints that need that. At least it works.
    PooreBoy and hoodie like this.
  18. boreas
    15,695
    Sonoma County, CA
    Something you'll want to check is the condition of the nylon thrust plate at the bottom of the spindle well. They all fail and disintegrate with age. Replacements are available on eBay. Replacing them is easy.
  19. Stanton681EEES
    Stanton681EEES Addicted Member
    7,332
    NE Ohio
    Ah the old girl cleaned up nicely.
  20. JJCalvillo
    344
    Portlandia
    Yeah cosmetically she's in good shape. Small chip in the gray paint just right of the front left corner plate, and some scuffing on the tonearm where it goes into the rest. The wood is really good, a couple of small bumps on the front edge is all I've found thus far.
    One thing I noticed was after I took it off to look at the cartridge and clean the sylus, the clamshell twisted a little clockwise when I put it back on. I had to twist it back a little to get the cart. vertical.
    Also, tested it with the strobe disc and it was spinning counter-clockwise at a respectable clip.
