Is this set up acceptable?
Discussion in 'Members' Systems' started by punprankster, May 12, 2018.
  1. punprankster
    punprankster Super Member
    1,023
    New Jersey
    I want to bring out my second table with a MM cart so I don't have to wear out my Denon DL-103R quick. I've read somewhere before that it is not ideal to put a table on the left side of an amp because it may pick up the hum from the amp's power source. Is that true?
    Is this set up fine or if not, what's the best way to arrange them? I don't think I'll be able to fit my stack in the middle cubby of the cabinet. Should i just lose the second table?
    safebet, Burner, BigElCat and 5 others like this.
  2. Silentnet
    956
    Charleston, SC
    Why would it matter if it's on the left or the right? Cause the cartridge is closer to the amp? If it sounds okay to you, there's your answer.
  3. punprankster
    1,023
    New Jersey
    Yes, that's what I read when I was starting in this hobby and it's stuck with me since. Never tried putting the table to the left of the amp.
    Thanks for the reply.
  4. avionic
    45,611
    Fort Dodge, Iowa
    Get it out of your head. Its nonsense.
    Soundork likes this.
  5. savatage1973
    6,689
    NW Pennsylvania snow belt
    Not all amps have the PS on the left side--so I guess it would depend on the amp, but the PS of the amp should be adequately shielded as to not interfere with any other components outside of the casing--or inside the casing, for that matter. If it is interfering with the TT/cart outside of the case, what is it doing to the phono stage inside of the case? Old wive's tale.
    What I see as least appropriate about your set-up is the proximity of the speakers to the TTs.
  6. punprankster
    1,023
    New Jersey
    I had them farther out before, about 8 ft apart. I'd bring them out again.
  7. punprankster
    1,023
    New Jersey
    There. It's out! Threw it in the trash bin! Poof! Gone!
    Thanks! Appreciate the info.
    savatage1973 likes this.
  8. Djcoolray
    Djcoolray Addicted Member
    6,553
    A rocks throw from JBLM !!!!
    Luxman 120’s with Yamaha speakers, I bet it sounds great.....
    7whales7 and Nightwisher like this.
  9. punprankster
    1,023
    New Jersey
    Yes, they do play really nice together.
  10. willyrover
    willyrover Super Member
    3,130
    Hamilton
    If you're cartridge is somehow picking up hum it "could" be from a power transformer nearby. They are, after all, both devices that use magnetic fields to work.
    I wouldn't say it's a rule though. If your setup sounds fine the way it is, no reason to change it.
    I have an MC phono stage in two boxes - linear power supply in one, and the rest of it the other. When placed close side by side, it is quieter with the power supply on the right. Notice the location of the transformer.
    punprankster likes this.
  11. jcamero
    jcamero Who are you people anyway? Subscriber
    4,210
    The Dairy State
    My only critique would be the tables are too close to the speakers, I'd worry about rumble/feedback.
    JH Magnecord and Grenadeslio like this.
  12. luxmaster
    luxmaster AK Subscriber Subscriber
    1,491
    West Coast, BC
    very nice, well balanced
  13. Nightwisher
    Nightwisher Farer In The Goldilocks Zone Subscriber
    3,342
    South Carolina
    Very nice! I love Luxman. I remember seeing your setup on Facebook earlier in the week.
    Unless you have an audible hum, you should be okay.
  14. punprankster
    1,023
    New Jersey
    I will be pulling the speakers farther apart. They weren't close when I only had one table up.
  15. punprankster
    1,023
    New Jersey
    Lol yeah I saw yours too. Didn't know if it's appropriate to greet you over there so i just gave your system a thumbs up.
    Nightwisher likes this.
  16. Guest126
    Guest126 Well-Known Member
    534
    It depends on your cartridge and turntable pickup wire isolation. If you are not hearing noises in the placement of your deck, then you're good.
  17. Nightwisher
    3,342
    South Carolina
    You could have, but thanks. :thumbsup:
  18. Dave_1962
    Dave_1962 Lunatic Member
    19,657
    Ontario, Canada
    Nothing wrong with the set up - no reason to dump the second TT.
  19. imral3
    imral3 Super Member
    3,172
    Blackwood, New Jersey
    Nice clean setup!
  20. Rome
    Rome Holsum Honey Buns Subscriber
    40,774
    Dallas, Texas
    Enjoy!
    Rome
    Ds2000 likes this.
