MannyE
Exterminate!
I quickly slammed a system together (literally less than 30 minutes) just to hear it. So glad it arrived exactly as advertised on ebay. Very well packaged. Sounds excellent. Phono stages are amazing, equaling any of my external preamps. The whole thing just sounds like a high end component. Which considering the price when new, it should. Pots are clean and the tuner brings in the awful Miami radio stations better than anything I've ever heard.
I can only imagine how much better it will get once the restoration is completed. This hasn't had any work done to it at all. So I can imagine there are a lot of out of spec components and I need to do the power switch and two other service bulletins Yamaha put out. Originally I was going to re-veneer it but it matches the speakers so well, I may just repair the scratches on the case (if you look at the left rear you can see them) and call that good.
It will most likely find a permanent home on that shelf where the xbox is sitting once I adjust it. I jammed the center speaker down there so I could easily and quickly hook everything up, but it belongs where the receiver is sitting now.
