"I've made a terrible mistake" - Gob
Discussion in 'Marantz Audio' started by StoryMe, Oct 30, 2018.
  1. StoryMe
    StoryMe New Member
    9
    Hangs his head and sighs.... I messed up.
    I needed to clean the knobs on a Marantz 2270 that I'd picked up and was refurbing a bit before putting into use. New bulbs, new velum, new power switch, cleaned pots. I was learning a bit as I went and had watched a youtube video suggesting that I soak the knobs in some 409 cleaner to clean them up. So I dumped some in a glass jar and threw the knobs in. Then forgot about them. Then left town for 4 days.
    When I took the knobs out, to my absolute horror, each looked like they'd been burned with a lighter. The structure of the knobs are the same. Same texture. No physical damage. But the visual is catastrophic. They are each their own very special brand of ruined: matted patchy black and splotchy chalky white.
    I don't know what to do. And of course these knobs are like $30 a piece on ebay. So I've essentially done something like $150 in damage in one fell swoop. The word crestfallen comes to mind.
    I'm wondering three things:
    Is re-plating possible?
    Is paint an option?
    Any leads on a reasonably priced set of replacement knobs?
    If anyone has any experience with similar or suggestions, or even if you just want to give me a hard time, I'm all ears. I certainly deserve it. I'm at a loss.
    Lesson learned: Don't soak your knobs in 409 for too long
  2. eizner23
    eizner23 Well-Known Member
    517
    Madison, WI
    409 they still make that stuff?! Must have been the ammonium that did that. Soap and water works well.
  3. 62caddy
    9,724
    NEPA
    Probably what happened is the protective clearcoat has been dissolved from the aluminum.
  4. Sandstrom
    Sandstrom Seldom turns out the way it does in the song Subscriber
    2,026
    Cincinnati
    I would try a good paste type metal polish like Flitz, Simichrome etc. It looks like the ammonia just discolored the metal. I would think you could bring those back with careful hand polishing...
    cason, John James and onepixel like this.
  5. StoryMe
    StoryMe New Member
    9
    Just the type of advice I came here for. I'll give this a shot and report back. Thanks Sandstrom
    onepixel likes this.
  6. kaplang
    kaplang Works for me ! Subscriber
  7. Beemerdoc
    Beemerdoc Grumpy Old Fart Subscriber
    659
    Sarasota, Florida
    Well, I would really like to bust your chops, but I feel generous today. :rflmao:
    Instead, Welcome to AK! :beerchug:
  8. Sandstrom
    2,026
    Cincinnati
    Nope...
  9. Fairlane
    Fairlane AK Subscriber Subscriber
    1,799
    West San Jose CA
    Little GTO, wasn't that Ronnie and the Daytonas?
    Sandstrom likes this.
  10. Fairlane
    1,799
    West San Jose CA
    Sorry but you said time to polish the knob(s) :rflmao:
    Seriously good luck with your restoration. Sometimes things seem worse than they until you get in there and try.
    Beemerdoc and John James like this.
  11. onepixel
    onepixel .
    35,171
    Maui
    I've used Simichrome and it works. You might even try some DeoxIT. It removes oxidation.
  12. wlhd1610
    wlhd1610 Penny and her new friend Sponsor Subscriber
    2,709
    Catskill NY
    Let me know how you make out with them.
    I can help.
    Bob
    Marine0811 and Snow like this.
  13. Pio1980
    Pio1980 AK Member Subscriber
    27,771
    Eastern Bamastan
    Simichrome or other polish will probably alter the original satin finish to something shiny.
    Be warned.
  14. Oerets
    Oerets AK Subscriber Subscriber
    10,699
    Derby City U.S.A.
    Welcome to AK!
    If you have access to a dremel type hand tool. They have a small brass wire brush and cloth attachments that may clean them up.
    Doubt it hand applied car or plastic polish will cut thru that buildup.
  15. Pio1980
    27,771
    Eastern Bamastan
    The black stain may be chemically reversed by the right treatment, but I don't know what that is.
  16. dr*audio
    18,858
    Cleveland, Ohio
    Finishing steel wool.
  17. Fairlane
    1,799
    West San Jose CA
    Used this on the aluminum case of an Ampex preamp and it worked well.
  18. Sandstrom
    2,026
    Cincinnati
    Agree, they will likeky become shiny, you might restore the satin look with a 3M maroon pad after cleanup...
    absolutely correct sir :D
  19. Pio1980
    27,771
    Eastern Bamastan
    I won't have steel wool anywhere around my work area. Maybe Magic eraser, nonmagnetic and non-conducting.
    Maybe this?
    Beemerdoc likes this.
  20. kaplang
    Nope! 409. The OP used 409 cleaned. Didn't use GTO. Don't you get it?
