Sure - that's why I searched, found, and linked to the Lansing article ...As noted in the article Heather linked, 12 cubic feet gets you a relatively flat response without using EQ like the 8 cubic ft B460 requires. I built one for my brother and it is thunderous on very little power. But it is big. I have the B460 at home and it is a keeper.
.... I have the B460 at home and it is a keeper.
Don, Have you tried these with your M2 DIY's?
Gordon, what did you use for a passive radiator? +7dB at 20 seems like it would be pushing a single 2245's Xmax limit, unless maybe you rolled it off below 20. I just might build one and get my fireplace back!
What are your thoughts on isobaric 2245 subs in parallel? I'm thinking 6cu. ft. per cab. Simple cone to magnet with the internal driver mounted to the front via 18" concrete form tube with long bolts. You'd never know it was isobaric to look at it. Eliminate even order harmonics with tighter overall definition.I built the passive radiator. If I had to do it again, I'd use something like a replacement cone for a PAS LX2800- giant rubber surround. I built it into a derelict 18" woofer frame.
The amp had a subsonic filter- I set it at 16Hz.
The boost actually was at about 22Hz, IIRC. And, the PR did a magnificent job of limiting woofer cone excursion at around 20Hz- better than a port, IME (much lower losses than a port tube). The 2245 cone would actually move more at 30Hz, than at 20Hz. The PR, OTOH, would be just, as the car audio guys like to say, "wanging away" at about an INCH or more of excursion, at high output levels near 20Hz...
Regards,
Gordon.
I think we'd all like to see a pic of thoseI have a pair of 2245H 18" drivers in 18 cu. Ft. vented enclosures of my own design. I was always quite pleased with them until I replaced them with a pair of Bill Fitzmaurice designed HT Tuba 1/8th wave folded corner horns using 15" drivers. The corner horns are also 18 cu. Ft. The JBL subs haven't been played since 2004 so I imagine they have bad foam surrounds. When I was using the JBL 18s in my system I loved the thunderous bass power down into the low 20s. The 2245H is a truly excellent driver.
Regards,
Gordon.
