I know these are perhaps not the top or middle of the line, but I purchased these cheap, and was hoping to put them in the garage for some music with a small receiver, instead of a boom-box.
Does anyone have any good, bad or indifferent comments on these, they are (1) 8" woofer, (1) 3" Mid-range and (1) 1" tweeter.
On one of the speakers, when the speaker wires are attached to the speaker, only the woofer plays, when I attach the speaker wire directly from the receiver directly to the tweeter, the tweeter plays, when I attach the speaker wires directly to the mid-range (when the mid range is internally wired) the woofer plays, but the mid-range does not. The Mid-range never plays . . .
I opened up the unit, removed the woofer, mid-range and tweeter to make sure all the connections were intact, the wires - cross over looked great, but the positive Ohm wire to the tweeter appeared to be a bit loose, I tightened it up, but still the same problems as noted above, only the woofer plays.
Any ideas, suggestions?
