The cabinets all look restorable. But don’t sand to much on the veneer. The grills can be recovered but how are the drivers?
I'm not sure whether A or none A - they are located in Auckland so the seller is holding them for me until I get up there in a couple of weeks
I recently let a set go roughly 3-4months back.
I was running a set of the A's for years, traded them to a fellow AKer for an amp a back in 2014.
One way of telling if the are "A" would be to check the serial number, it will have a "A" stamped after the serial. Kind rare actually, hope for you sake they are.
I let go of my last set of 110's to keep my L26's in the spot. (Small space, but lots of gear)...
If you like the 110's, you should give a set of 26's a listen.
Kind Regards,
John
Hi John, I would listen to the 26 given the chance but my location on the planet limits my options somewhat ! Funnily enough, on our auction site, there is a pair of L36 Decades - it's quite unusual for two pairs of vintage JBL to appear within days of each other. The 36 are pricey though, starting bid is $260 NZD but they do look to be in very nice condition.
The drivers in the pics do look right, for what that's worth. Should be LE-111A (AlNiCo) in the first version. The A version has the H woofer which is the ferrite magnet.
Not selling mine, I did pass along the L-166's though. And the L-40's.
I liked the 110's over the 166's as well. I think the 26's and the 16's are my all time fav "bookshelf" style JBL.
If you like the 110's you should try to find a set of the 4401's. I had a set paired together for a good while. They do well together.
Nice grab!
Of course we expect lots of pics, and I hope the "damp" cab isn't to badly damaged.
Cheers, Glenn
Finding 4401 here in NZ would be literally finding a needle in a hay stack. The market here is just so tiny, good stuff does surface occasionally but then there's a feeding frenzy for it.
I guess I got lucky with these L110's because the auction was for an amp, CD player and a speaker. I enquired if the seller had the other speaker and he said yes but it got damp so he was drying it out. He also didn't list the speaker brand in the auction - that always deters the keyword searchers !
