joshvito
I recently moved,and had to tear down my previous listening space which I documented in another thread. (http://audiokarma.org/forums/index.php?threads/joshvitos-small-listening-space.643985/page-4)
The new dedicated space is a bit larger at ~350 sq ft, compared to the old ~150sqft. I a currently waiting on a contractor to install the hardwood, so I can only share empty room photos and a rough floor plan.
However, I would like advice on general placement of my gear as I may have the contractor run a dedicated electrical circuit if it is not cost prohibitive.
From the narrow side of the room.
From the wider side of the room.
I've pulled up the nasty carpet in leu of the new floor install. The room appears like it was two bedrooms at one point before the adjoining wall was removed.
Here is my rudimentary floor plan drawing.
I am thinking I want the speakers near the 'bottom' wall and they should fire North towards the top wall.
The listening position could be just north of the door/entry.
What do you think? What's the best placement?
Gear is in my signature.
