What Merrylander said..... 4 minutes doesn't make for much of a listening session!But it only plays about 4 minutes then shuts off:tears:
After waiting a few minutes, when turned on, it does the same thing.
Any suggestions, this thing is beautiful, and I would like it work properly.
Flip the AC plug? They were all non-polarized back then. Maybe also try to run the TT ground wire to the Yami.
1 and 2 MM
Same result:tears:
But is the tt grounded to the 2020? Just because you got no hum with the 'sui doesn't mean you don't have to ground the tt to the 2020.
Is the hum in both the L and R channels? If it is, then I think that would point again to the power supply since it's common to both.
Also, can you hear the hum in the other inputs if you turn the volume up? Like if you have nothing plugged into the Aux input, it should be virtually hum free even with the volume on 10. If you hear any hum, that's another sign that the supply rail is hummy.
