I just bought a car, as a run-around car. It is a 1988 Buick riviera, with the GM 3800 V6 engine. 110k miles, and it is in pretty good shape, with only a very minor bit of rust near the edge of the hood(Heck, my van, an 2001, is getting that!!), and no other real inperfections in the body, other than near the top of the left headlight(a bit of damage, someone must have bumped sommethig, but very minor.) The interior is pretty good, the headliner is intact, of course the seats are cracked in places(leather ALWAYS seems to do that!!) as is the door arm rest. The A/C needs recharged. The window on the passenger side does not roll down right(you can hear a grinding, like a gear on the motor). But other than that--the inside is good. ALL gages work, including the touch screen and dash(except for the EL backlighting for the left and right switch panels--I suspect that it is a bad inverter,one of which I have a spare, from my previous rivs, I think). The radio is a BOSE, unfortunately, but does work.
As for the engine--it runs pretty good, NO knocks, or rattles, and NO smoke out of the oil filler, at idle or above. The tranny shifts smoothly. The CV joints do NOT make any noises, going around turns. The exhaust system is good, and quiet. The temperature holds pretty well,and the oil pressure is in the ok range--32-38 PSI at about 1700 RPM and about 25-30 at idle. Unlike my van, which needs a rear seal and is leaking about a quart of oil per wwek, this old car does not seem to leak ANYTHING!!
It runs and drives quite well-EXCEPT for a rough idle--I pulled out the codes, and a eo27 and eo28 are there"history". I suspect possibly the mass air flow sensor, dirty injectors,or such, may be bad, and it will need plugs. Under power, it runs good, and pretty swiftly. It DOES need struts.
And the price-- I paid $700.
Seeing the blue book on these--I don't think I did bad. Plus-- I got it locally--less than 2 miles away-- so there was no "cost of driving it back" from a long distance.
I figure on doing most of my driving in it from now on, work, radio clubs, "pleasure driving" flea mkts, routes(around here) and so on. My van will be reserved for out of town routes, swap meets out of town and long trips like to estes.
