Just Finished My Downdraft Sanding Table
Discussion in 'DIY' started by elcoholic, Jun 16, 2017.
  1. elcoholic
    elcoholic AK Subscriber Subscriber
    13,784
    Fountain Valley, CA
    Nearly five years ago I posted about building one of these. Well after 3 years of getting around to and 2 years in Atlanta it finally made it to the the top of my projects list. I kept it simple and cheap using a couple of 20" box fans I had on hand, 24"x24" pleated filters, some window screen for the pre-filter, a 1/4 sheet of hardboard for the baffle and a 1/4 sheet of pegboard for the top. I had a bunch of surplus IKEA phenolic back splash panels to enclose the sides of the frame. Originally I tried enclosing the bottom, using no filters and connecting a 4" hose from my 2hp duct collector thinking the fans would pull the dust in from the surface and the dust collector would pull the dust from the cabinet. It didn't work. Too much turbulence and static pressure such that there was very little suction above the fans and in some places reverse airflow.
    The fun part was perforating the top which I did last with the fans running. After a couple hours I had punched the required 946 3/4" holes with my big plunge router. This brought it to just under 50% open. The table did a pretty good job of eating it's own dust but the 3hp router's dust velocity is too much for it.
    The table is a secondary system meant to pull off and filter what the the Fein vac hooked to my sanders misses. Hopefully I'll be able to continue working with the tropicals and walnut I love but have become sensitized to without wearing a respirator. Time and my sinuses will tell.
    Sadly there was some collateral damage. When flattening the support grid for the top a shallow screw became a 'shiner' and deeply gouged the bottom of my prized Lie Nielson #4 bench plane. Made me a bit sick to f' up my plane. A couple hours of lapping the sole and grinding & honing a new bevel on the iron will set it right but that's not much of a consolation for shortening an heirloom quality tool's life by 25 or 30 years.
    TudorTurtle, CT_Ohio, djnagle and 3 others like this.
  2. bhunter
    bhunter The Spherical Cow
    1,662
    La Jolla, CA
    That looks nice. Sorrt to hear about the #4. As you know, that's a quality plane.
  3. NH-MAN
    NH-MAN AK Subscriber Subscriber
    341
    Thats awesome! you do know we must see inside;)
  4. BigElCat
    BigElCat AK Subscriber Subscriber
    6,985
    South of Kansas City
    Looks good !
    I have that same vacuum cleaner hooked to my compound miter saw. It's the quietest shop style vacuum there is.
    Fein rules !
  5. elcoholic
    13,784
    Fountain Valley, CA
    The L-N's are wonderful tools. I also have the small shoulder, chisel, and the adjustable mouth low angle block which gets the most use. In addition to the L-N's I have #5 & #7 Bailey's. I had a very nice #4 Record I left with my son shedding weight for the recent move. I would have much rather dinged it.
    OK I'll take some more pics and post soon.
    Yes and they filter to 1 micron while pulling nearly 100 inches of water. The bypass cooling is a great feature also. I have a second one I can use for vacuum clamping all day and it won't overheat the motor.
  6. gadget73
    34,885
    Southern NJ
    Almost looks like you re-purposed a console stereo cabinet. Maybe thats actually a good way to recycle a crappy console.
  7. elcoholic
    13,784
    Fountain Valley, CA
    Yes it does have the basic proportions for a console. The dimensions were derived from a 24x48 sheet of pegboard and the height to match my table saw. It will do double duty as an infeed table.
  8. cannext
    cannext Active Member
    400
    So many projects , so little time .
    Looks good .
    Regarding the plane , I "strongly dislike" (insert cussword ) when that happens , been there .
    Regards F.
  9. 2526
    2526 AK Subscriber Subscriber
    3,476
    Pittsburgh, PA
    Nice job. You appear to be very serious regarding dust management. Sorry about your plane.
  10. elcoholic
    13,784
    Fountain Valley, CA
    Yes I guess I am serious about keeping wood dust out of my lungs.
    I LIKE MUSIC and jbailey930 like this.
  11. bberkom
    1,220
    Nashville, TN
    The scratch in the sole of your plane really sucks! But instead of relapping the sole to get rid of the scratch and losing all of that material, you could just leave it. I doubt it will affect the performance of the plane, so maybe just work on the blade first and see how it does.
  12. jbailey930
    jbailey930 AK Member Subscriber
    798
    N. Va
    hey - that is a great project, and I am very envious! I truly hate sanding and do work out my garage like you and in the basement. Cherry also gets to my nose, especially if I burn it! I need to find an adequate over-arm dust extractor for my Delta TS.
    For AK content, do you have a stereo in your shop? I am using my Yamaha CR-640 with JBL L20s. I hate to get that dusty, so I use towels and cardboard to cover them.
    I too have the same Fein vac. It is so nice - powerful and quiet. Shame about the plane. I too lust for LN. Visited the HQ up in Warren, ME once. I have their low angle jack, shoulder and small block planes along with a set of chisels.
  13. elcoholic
    13,784
    Fountain Valley, CA
    I usually do have a receiver and speaker system in my shop and use an iPod and 30-pin dock cable. For the first time in many years I don't. For the time being just my older-than-dirt JVC boom box sitting on top of the SCMS dust hood. It's so old - dual cassette, pre-CD and I'm amazed that it still works.
  14. toxcrusadr
    30,547
    Central Missouri
    I have a miter saw and have been struggling with how to capture dust. It has a little inlet behind the head for a hose, but only 2" or less diameter and it just doesn't catch it all. I like your big box arrangement.
    Was planning to make a ceiling mounted air cleaner. Actually wall mounted, behind the vertical pipe coming out of the woodstove. Fans will be repurposed dehumidifier fans, and the filters, I got a pile of 12x20 very cheap at the Habitat Restore. The breeze from the filter will help extract some extra heat from the chimney pipe, and it will clean the air in the process.
  15. elcoholic
    13,784
    Fountain Valley, CA
    I run a 4" hose from the DC to a tee fitting below the box. A 4" runs to flange connector for the box and a 2 1/2" hose runs to the SCMS with an adaptor fitting. Good luck with your air cleaner project.
  16. Ohighway
    Ohighway Wannabe Minimalist Subscriber
    Do the box fans you used have totally enclosed motors? I hope so .....
  17. elcoholic
    13,784
    Fountain Valley, CA
    No, but neither does the squirrel cage blower in my Jet air filtration system which is of course UL. This is probably because the air supply is filtered. My 2 hp dust collector does have a TEFC motor and a sparkless impeller. Both of which make a lot of sense. The box fan motors don't have starting switches or any arcing contacts so my guess is they are shaded pole induction motors. I think I'm good.
  18. loudnoises
    loudnoises Escalates Quickly
    928
    Pondside, NH
    I have the equivalent of a fume hood for mine, heavy dust falls and the lighter stuff gets sucked up. No vacuum system seems to work adequately on chop saws
  19. homebrew
    homebrew Active Member
    164
    It can't have good suction is it's not loud! ;-)
  20. BigElCat
    6,985
    Shah !
    That Fein is a third cousin, twice removed from R2D2. You can see the resemblance.
    The exhaust port goes all the way the motor-head. It out sucks a 6hp Shop Vac, and just makes a 'whooshing' noise.
