JVC TD-V541 bad caps
I got my deck out of storage to convert a cassette to digital. It had a similar issue. Tape speeds up then slows down in about one second intervals. You can hear this happening when the desk is on, even if a tape is not in it. The JVC TD-V541 normally runs the capstan motor all the time the deck is powered on.
Here's some details on my repair in case someone else comes along and also needs the same thing.
The Servo board attaches to the back of the tape transport. I detached all the wires leading to the transport. Two connectors on the main board have slides that release the raw cable. The other white cable has a slide release on the transport end. There are 2 audio connectors that just pull off. Be gentle with the cables on these especially as they are delicate.
I then removed the 4 screws holding the transport in place, removed the entire transport assembly, and then removed the 4 smaller screws on the back to pull off the plate with the servo board attached. There is an orange connector on the right in the pictures above. Pull this out carefully. There are 2 black wires soldered on to the servo board that are part of the motor. You can see these on the left in TAGO_MAGO's pictures. I think this is some kind of tachometer. At any rate, I left those soldered on and just worked on the servo board while it was still hooked up. I did not remove the belt, or the capstan flywheels.
I picked up a couple of 10 μF 25V? electrolytic caps from a local electronics shop. Removed the 2 bad SMD (surface mount device) capacitors labeled here as "10 16v" or 10 microfarad 16 volt. Laid the new caps on their sides and soldered them in.
Deck is back up and running. I have not decided if I'm going to order in exact replacements from Mouser or just leave the over-voltage caps. I can't recall if they are 25V, but they are over 16v and perhaps twice the physical size of the originals.
Thoughts?
Thanx so much for this post. It led me to the exact problem I was having! I hope TAGO_MAGO got his deck fixed. I like this deck. My other deck (a BIC T-3) needs all the belts changed. The belt on the JVC TD-V541 still looks great.
Wish I had service manuals for both of them.
