Stink Bear
I just acquired a KA-3500, the previous owner said that it keeps blowing fuses.
I took the cover off and looked around, there has been something spilled in it at least once.
I did a little cleaning so I could see the components better, I don't see anything that looks burnt.
I used an ohmmeter on diode function to check the output transistors, I am getting different readings
between the same transistors on the different channels. One transistor seems to be shorted. Since
this was done with the transistors in circuit and I am new at this I'm not sure what to do next. I think I
should pull the board, remove the transistors and check them.
I'm wondering if there is anything else I could or should do before I start taking the board out. I
considered putting in a fuse and powering it up on a DBT to see if it might stay powered on and work
long enough to isolate to one channel but I think I could also cause more damage doing that.
Any suggestions?
Thanks,
Brett
Any suggestions?
Thanks,
Brett
