Soundslave
Member
i have a ka-7100 that I've recapped the P/S-Amp board, new relay, Q34, d27. Could not see what was causing the loud pop at turn on. After replacing the relay I can see that at cold turn on the relay makes contact then releases for a second then makes contact and holds. If I turn it off then back on it will hold without any bounce. Also should there be a delay at turn on before the relay engages?
