djackman123
New Member
Hi all,
I am looking for some input on my KA-9100. I had it stored for about 25years. After reviving it and cleaning the contacts. It has been running like new. The only issue is that the two phono outputs are running on the right channel only. I have sprayed the switch and changed the rca connections to make sure it wasn't the cables-no luck. I even sprayed into the rca connections on the back of the amp. My conclusion is that the left preamp is bad. Any suggestions or input would be appreciated. David
