I'm not sure of the type of crossover used in the Kappa 8, but the crossover frequency is not a hard cutoff, it is sloped based on the design. Having said that, though, I'd expect the removal of the jumpers on the binding posts would completely separate the woofer's crossover from the rest. You might want to check out the schematic (see link above) for more info. Keeping that in mind, your low pass frequency on your electronic crossover should be slightly higher than that of the low crossover frequency on the speaker, and likewise the high pass frequency should be lower than that same frequency, since you're still going to have the passive crossover in the circuit, and if you make both frequencies the same, no matter what slope you use, there's going to be a trough in the frequency response.
