nailzgun
Infinity - Threshold nut
Well as I mentioned in my last thread I got the Kappa 9's home and was a little underwhelmed by the sound. The wood though is virtually mint (just a couple of spots of paint, now removed) and has been treated with a special finish my buddy makes himself. They positively glow.
The electronics is another thing though. I removed all the drivers and the cross-overs. One of the rear emits is cooked. All the other drivers read great on the multi-meter. I was truly surprised to find the woofers had been replaced with (new) factory units from Infinity. Even more surprising was the labels on the woofers. They were control woofers from the IRS series. accelerometer wires were snipped, but suddenly thoughts of servo controlled Kappa 9'ss ran through my head. Very coool.
I called the 'man' at Millersound to ask his opinion regarding this idea and he strongly advised against it. He also suggested that I check under the dust caps to see if there was a foam core filling the voice coil space that tremendously inhibits the drivers ability. This was used to stabilize the accelerometer in these drivers. No foam core and no internal wiring so Infinity had already done this. Mr. Miller also mentioned that the crossovers on the 9's were problematic, specifically the inductors used on the woofers and this was likely the place where my sound problems lie.
So now I have these stunning cabinets sans drivers and electronics. The cross-overs I initially thought to do myself but have access to some truly magical electronic technicians locally so I am sending them out. (The Sonic Frontiers gnomes are all local as is Dan Santoni who does my Threshold gear.) All of these guys are electronic artists who will upgrade these things mecilesssly.
I will also take the opportunity to replace the Wonder Wire with something more transparent internally.
Anyway I will keep you all abreast:scratch2: of my progress.
