Kappa 9A ans Accuphase
Discussion in 'Infinity Loudspeakers' started by FrankieS, Aug 1, 2018.
  1. FrankieS
    FrankieS New Member
    9
    Hi, dear all,
    does somebody know from experience, whether integrated Accuphase E-470
    would fit the Infinity Kappa 9A? Or even E-370, E-270 ?
    Ratings:
    E-470: 180 W 8 Ohm, 260 W 4 Ohm
    E-370: 100 W 8 Ohm, 150 W 4 Ohm
    E-270: 90 W 8 Ohm, 120 W 4 Ohm
    thank you kindly in advance,
    bye bye
    FrankieS
  2. swechsler
    swechsler Frog Whisperer
    5,495
    7th row center
    Hi Frankie,
    IMO you're much better off with separates. While I'm unfamiliar with the amps you've mentioned, I'm not aware of any successful pairing of an integrated amp or receiver with Kappa 9s. They really are demanding speakers in terms of electronics.
  3. Silentnet
    1,165
    Charleston, SC
    If the integrated in question doesn't have rated output in to 2 ohms, stay far away. The Kappas will destroy it (or it them).
  4. FrankieS
    FrankieS New Member
    9
    thank you !
  5. FrankieS
    FrankieS New Member
    9
    thank you.
  6. Bahamayellow
    Bahamayellow Well-Known Member
    833
    I looked up your integrated amp and they look well built and powerful. Accuphase makes good stuff. I wouldn’t attempt it on the K9s though. Go separate amps like the others have said. Also post pictures of your K9s when u can.
  7. chef free
    chef free AK Subscriber Subscriber
    2,298
    Hayward, Ca
    The Accuphase E-470 is a modern and robust amp. It is a MOS-FET triple parallel push-pull design and has a damping factor of 500, so it has been designed to handle low impedance loads. This amp would be a good match for Kappa 9. Plus it has great features, five RCA inputs, two balanced inputs, a real tape monitor, pre-out/main in in both RCA and balanced, and groovy power meters.
    BUT... they ain't cheap! Even used they'll cost six big ones, for that kind of scratch, you could choose a lot of other amps.
  8. 7.62
    7.62 Gearhead Subscriber
    1,796
    Las Vegas
    I'm being totally facetious here, hook'em up and if you see Or smell smoke they ain't doing it :biggrin:.
  9. swechsler
    5,495
    7th row center
    That's a bit pessimistic, I found a few selling in the $5k-$7k range.
  10. chef free
    2,298
    Hayward, Ca
    Wow! New ones?!?
  11. swechsler
    5,495
    7th row center
    I didn't look closely, but probably used. But are you seriously suggesting that one of these, used, should sell for >= $100K? Or did you mean five big ones?
  12. chef free
    2,298
    Hayward, Ca
    By "six big ones" I meant $6,000...
  13. swechsler
    5,495
    7th row center
    Yeah, you're right, I don't know what the hell I was thinking. Your estimate's right on the money. That sort of coin will get you an awfully nice preamp + two power amps (for biamping), such as an Aragon 28K plus a pair of 4004s or even 8008s..
