cr4zyg047
New Member
THE MISSION:
Having purchased a pair of KEF 103/4s about a month ago - I have set off to tear the things to pieces and get it back to peak running condition. The previous owner had done a fine job refoaming the internal bass woofers - but there is work yet to do. One tweeter sounded 'OK' at best - the other was so quiet, it was practically a paperweight.
These tweeters are notorious for having issues caused by dried ferrofluid. This magnetic fluid was used to cool the voice coil and improve power handling - but over time, turns to a sludgy paste that impedes the performance of the coil. My goal was to replace this fluid and restore the tweeters.
The double-edged sword (that I didn't find out until I got the damn things open) - is that the dried ferrofluid grips onto the voice coil - making it harder to extract. While opening one, the coil was no longer attached to the diaphragm itself - which I believe accounts for the lack of output I had seen. The second unit's voice coil was stuck in the sludge - which I believe stressed the adhesives connecting it to the diaphragm. Lastly - the glue that is inserted into the little notches held the diaphragm firmly to the cosmetic dome shield on the outside - so separating the dome took the diaphragm with it. Had the ferrofluid not separated them - that would have.
NT25 tweeters are no longer in production - spare parts just don't exist. So repair is my primary option.
THE QUESTION:
Would one use speaker-grade black rubber cement to adhere the voice coil to the diaphragm? I ask this because every diaphragm I see online has the coil directly attached - and when I press down (gently) on the diaphragm while suspended over the coil (while running), the sound is full and bright. I believe the answer is yes - but it never hurts to ask before doing something potentially stupid.
Were I to do this, I would line up the coil and diaphragm - determine the points where they meet - and put four dots of the rubber cement on the coil and diaphragm respectively - and place them together with the cement points alternating. I bought the white speaker repair glue from parts-express, but I don't know if this has the tack-factor to last in this kind of application.
THE PICTURES:
THE QUESTION:
THE PICTURES:
