Sam08861
Super Member
I've got a GE-7030 equalizer, that has developed an odd condition..
All functions work, sound is clear on both channels, but ~20db lower in volume than the input. I am guessing this amount, because when using the attenuate function on my pre-amp, it seems to be about the same volume, when bypassing the processor circuit. I've ruled out the preamp by using jumpers on the processor out/in. When using the eq's bypass mode, the volume doesn't increase. Turning the unit off, and it's just slightly louder, but still ~20db less loud than if the unit is bypassed. (either with patch cords or the pre-amps bypass function)
Here's the eq, doing it's thing with the top off.
So I am thinking the amp section in the EQ is not working.
A web search suggests checking capacitor c93, but I don't have a capacitor checker.
See here -----> http://fixmystereo.blogspot.com/2015/01/kenwood-ge-7030-graphic-equalizer.html
In my particular case, the sound isn't distorted, but very low, as opposed to the person above's issue.
The suspected cap from the above link.
In my spares, I do have a 160V 10uf cap that I could try as a replacement. Unfortunately, it's radial and the voltage is not the same. (spec is 35V, so this is much higher)
In my unit, all capacitors appear to be ELNAs and the originals as I can't find any evidence on the solder side of these being replaced, and have found threads with folks saying that they also had Elnas as OEM.
Couple more shots from the top, showing the boards..
I've tested the voltage at all the test points on the board that have the voltages labeled, and all checks out. Adjusting the EQ settings actually works, so it seems everything is working and I am suspecting the AMP sections.
Any advice where to start?
Shall I just try replacing c93 the the 'suntan' cap as a test, or is there a more scientific way to narrow down what the problem might be?
Will be glad to take close ups of anything if that helps.
Looking at the service manual, I can't see any specific steps or adjustments, but the schematics are provided. Unfortunately, I'm a total novice with electronics, so not sure where to start.
Found the service and owners manuals here for easy reference...
https://www.hifiengine.com/manual_library/kenwood/ge-7030.shtml
