Kenwood KA-3500 distortion left channel only! Guidance needed.
Discussion in 'Kenwood-Trio/Kensonic-Accuphase' started by Longhorn262, Aug 14, 2017.
  1. Longhorn262
    Longhorn262 New Member
    41
    Let me walk you through what I've run into and done since receiving this amplifier.
    At first I had 3volts dc on the left channel speaker terminals so I replaced all out put drivers with the recommended replacements in another topic (FJP5200/FJP1943 (230V, 15A, 100W, 30 MHz)) also replaced all zener diodes, electrolytic caps and bias resistors.
    I now have music out the left channel but viewing a 1khz tone on the scope it's very distorted. The right channel sounds very very clean. I even bypassed the pre amp by cutting the blue and yellow wires from the pre amp out to the amplifier board and ran wire straight from the back of the aux input jacks just to rule out the pre amp but it didn't change anything. Still going to recap the pre amp as soon as I find a solution to the power amp.
    I have a decent scope so if I could get some guidance on where to look I could report back with my findings.
    Some of the early transistors have higher voltages than what's listed in the schematic. And distortion starts around qe1 and qe3 on the emitter I believe. I'd have to double check just going off memory here.
  2. mbz
    mbz AK Subscriber Subscriber
    1,302
    Melbourne, Victoria
    I'm a little confused about the need for cutting wires etc... You have a scope, ideal for a problem like this.
    I think you are saying the problem/distortion is in the left channel, power amp stage.
    Confirm by checking for distortion at either leg of Re3 (2.2k) or pin 1 (normally a post or solder pad for wire)
    on the left power amp, expect no distortion.
    Check for distortion at
    Qe5base (alt Re9 junction)
    Qe17 base (alt Re19)
    Qe19 base (alt Re23)
    I don't like measuring at transistor legs, small space, one slip... So alternative components listed. Measure at the common node/junction
    of the transistor and resistor.
    Is the 1kHz sine wave distorted on the top half cycle, bottom half or both top and bottom.
  3. Longhorn262
    41
    Previous owner already cut the wires so I figured I'd double check to be sure. Pre-amp has a clean signal. So yes distortion is present only in the left channel of the power amp.
    I will check these today and report back.
    The top half of the sine wave is skewed near the early stages of the signal. I will probe those points today and report back with my findings.
  4. Longhorn262
    41
    There is distortion at the base of Qe5. About .4v almost a square wave top and bottom. Does this mean qe1 and qe3 are bad?
  5. Longhorn262
    41
    Here is the output for both channels. Also shows some dc voltage from both channels.
  6. Longhorn262
    41
    Next two photos are the base of qe1 and base of Qe5.
  7. mbz
    1,302
    Melbourne, Victoria
    Input to Qe1 looks reasonable, output from Qe1 to Qe5 is not ok. Suggest replace Qe1 and Qe3 with closely matched hfe pair, the
    service manual has them as 2SA620 however actual components may differ.
  8. Longhorn262
    41
    Yeah after looking in the service manual they do not look like the original 2sa620wn that is listed for either channel. They are stamped A640 F7Y.
    Also here is how I mounted the fairchilds for now using bits from the old batwing. Will probably do it right once I fix all the faults.
  9. mbz
    1,302
    Melbourne, Victoria
    2SA640. I think KSA992 would be a suitable replacement, suggest waiting for others to chime in and confirm...
  10. Longhorn262
    41
    Thanks that's what I figured. Would you suggest replacing both channels or should I leave the right channel alone. Yeah hardest part is finding and choosing replacements. It's been almost 10 years since I went to school for EE but I've been teaching math and everything I learned about transistors is all but gone except the basics lol
  11. mbz
    1,302
    Melbourne, Victoria
    I don't see the need to replace the transistors in the right (working) channel. Most multimeters can measure hfe, best to buy the KSA992
    in tape/ammo format and measure each writing the hfe on the tape underneath. Try to get under 10% variation, buy at least 20 KSA992's, they
    cost like 10c and are widely used.
  12. Longhorn262
    41
    Awesome mouser stocks 4 or 5 different ones by looking at the documentation they separate them based on gain and packaging.
    Looks like this 512-KSA992FATA would be a good option. I read on here over 300 would be good and FA designates 300 to 470.
  13. mbz
    1,302
    Melbourne, Victoria
    This would be fine.
    I think most people would go for the KSA992FTA to get a slightly higher gain 300-600, the FATA is probably better as it's a closer
    group. Both are ammo style with bent legs.
  14. Longhorn262
    41
    Okay finally got around to replacing q1-4 with matched sets. Still get distortion on scope above 4v at the speaker outputs. Below is a shot of emitter voltage of q1 and 3 with volume knob below half and second as you turn it up past half way.
  15. Longhorn262
    41
    Here is a shot of the collector for q1
  16. Longhorn262
    41
    Nvm figured it out input signal to power amp is good if I probe before C1 รง3 and r5 but after these it is distorted at the base of q1
    Ignore this I thought q1 and q3 base was tied together
  17. Longhorn262
    41
    Base of Q1 looks good to 1 volt but the base of Q3 is what's distorted above .3 volts
  18. mbz
    1,302
    Melbourne, Victoria
    The base of Qe3 is effectively the speaker line/wire. The distortion might be injected by the outputs Qe21, Qe23 however the cause
    may be before then. Suggest start at outputs and work back, check for distortion at,
    Qe21base (measure at Qe17e/Re41)
    Qe23base (measure at Qe19e/Re43)
    Qe17b (Re19)
    Qe19b (Re23)
    I would be a little surprised if you get 0.3Vdc at Qe3b, likewise 1Vdc at Qe1b, both should be near zero Vdc.
  19. Longhorn262
    41
    I replaced both sets of outputs I'll work my way back and post the results. Thanks again.
  20. Longhorn262
    41
    I get 32mv DC on right channel and 34mv on the left channel.
    I was talking peak AC at Q1b is 1v 1khz sine wave. When Q3b gets above .3vac it starts to distort. This is using the volume knob.
    Just checked all the points suggested above and there is distortion at every one of them.
