Kenwood KA-3500 recap
Discussion in 'Kenwood-Trio/Kensonic-Accuphase' started by Dingman, Apr 14, 2017.
  1. Dingman
    Dingman Do you know where your towel is? Subscriber
    2,536
    Des Moines, Ia
    Hiyas guys~ this is my first time in the Kenwood section.
    You fools, you left the door open. :)
    I have a KA-3500 that I'll be re-capping. Originally came to me as having right channel not working properly. Owner had identified that bias couldn't be set properly on Rch.
    I replaced Qe15,17 and got bias correctly set on both channels.
    EDIT: this repair is suspect. I can't explain why bias is OK now. Original transistors test fine on two diff cheapo testers.
    Nevertheless, this is a 1977 vintage unit. Since I already had to remove the boards (a little tricky) for the bias issue, now is the time to replace electrolytics. 40 years old is good enough, thank you.
    Unit is opened, boards half-way out. I removed both the pins conneting main board to black wires (neutral) of the transformer. This allowed me to get the main (and thus other) boards out for work. The bottom of this unit does not come off, you have to remove all the boards.
    I'll update as needed! I hope to have this all done in a week or two. Or three.
    Tttank likes this.
  2. SoundOfSound
    SoundOfSound Super Member
    4,069
  3. hopjohn
    hopjohn Silver Face Subscriber
    1,115
    Dallas, TX
    Welcome to the Kenwood forums. The KA-3500 doesn't get much play here it being pretty much BOTL. Any photos, troubleshooting, or information you provide is greatly welcomed and your trail to blaze.
    I like the lazy susan BTW.
    Cheers.
    Dingman likes this.
  4. gort69
    gort69 AK Subscriber Subscriber
    1,154
    Vancouver, WA
    I recapped one last year- unfortunately this is the only picture I took. Lots-o-disassembly! The spring clamp was just to hold it somewhat upright. Surprisingly powerful and nice sounding amp - worth the effort.
    Tttank and Dingman like this.
  5. hopjohn
    1,115
    Dallas, TX
    You aint kiddin' Where's the chassis? Haha :D
  6. Dingman
    2,536
    Des Moines, Ia
    Actually, I do have a question. The rectifier looks to be fairly robust (and easily replaced), so what's the opinion on upping the final filters from 6800\42 to 10K\50?
    I'm thinking this will be just fine and in fact should be a nice upgrade.
  7. Dingman
    2,536
    Des Moines, Ia
    Got some work done on the main board - kinda going overboard on caps, but I have them on hand, so in they go. Some of this is signal path (I think), so not wasted caps. The black caps are general purpose, they are in the power supply side (pretty sure). LOL, I'm not great at understanding the schematics.
    I thought about removing completely from the chassis and I still might. But working like this on the main board for now.
    Kenwood KA-3500 recap 02.jpg Kenwood KA-3500 recap 03.jpg Kenwood KA-3500 recap 04.jpg
  8. Dingman
    2,536
    Des Moines, Ia
    This is baffling - I've never seen this before. The main filter caps, 6800uf, both tested out at around 2400uf. Now, I am wondering if I should put 10kuf back in. The owner liked the sound before and going from 2400 to 10K is a large jump. But of course, the spec is 6800uf. Hmmm.
    And a few other small caps testing bad as well. (in each pair of lines, top is old cap, bottom is new cap).
    Kenwood KA-3500 recap values 01.jpg Kenwood KA-3500 recap values 02.jpg Kenwood KA-3500 recap values 03.jpg
  9. DrumminDaddy
    DrumminDaddy Hit it, Baby !!
    2,321
    Lost in musing circumstances
    Wasn't me...:rolleyes:
    Whatcha got going on with that black unit on the back of the bench? Can't quite make it out.
  10. Fredrik 1977
    Fredrik 1977 Super Member
    1,196
    Sweden!
    stick those 10000uf in, it will be just fine!
  11. Dingman
    2,536
    Des Moines, Ia
    It's my home made connection panel. I got tired of re-arranging connection cables, depending on if I was working on amps, pre-amps, speakers, ect. So, I got a backpanel from some generous AK'er and used the terminations on the back to keep things cleaned up. A little, I guess it's still a little ugly, but it does work and is fast for changing configuration. Wired that up to an impedance matching speaker selector.
    milo63 and DrumminDaddy like this.
  12. Dingman
    2,536
    Des Moines, Ia
    Yes, I think so too. And the ones I already have will save owner money (I just checked, replacements will be another $12) and they fit perfectly. I suspect there may be a significant low freq boost going from 2400uf to 10kuf? Is that right?
    For entertainment~ picture of me tracing signal - I've already put a few nice caps where they weren't needed. Doh. I got ahead of myself.
    NOTE that C1 and C2 both have a 1uf\50v installed, NOT a 0.47 as the schematic and parts list show. Not a huge deal, but I stuck with 1uf
  13. Fredrik 1977
    1,196
    Sweden!
    yes it will be one hell of a boost in performance.
    if those 1ufs are signal coupling, i´d consider using mkt filmcaps in those positions.
    and i like your homemade patch-bay:)
    i use a crappy technichs amp where i have mounted the speakerposts and aux-in, pre-out and mainamp in. on the front :D that way it can handle most of what i need to test. it works but i think its starting to act up on me! i´ll make something more serious later on.
    Dingman likes this.
  14. Dingman
    2,536
    Des Moines, Ia
    they are coupling, and I put WIMA's in there. I have some mkt type 1uf's and do use them sometimes, the WIMA are pretty sterile. I think the mkt's aren't so... cold? All subjective.
  15. Fredrik 1977
    1,196
    Sweden!
    YEY! very good!
    well now i saw you list some posts up. :oops:
    Dingman likes this.
  16. Dingman
    2,536
    Des Moines, Ia
    I don't always succeed but I try to bend the leads over to get a mechanical connection and not just rely on the solder to make the connection.
    sdw54 likes this.
  17. Fredrik 1977
    1,196
    Sweden!
    well i dont think the wima is especially good, but its the only brand that makes em in the perfect size for this application. and they are way way way better than any electro cap.
    i would like ROE mkt caps in the sizes fitting preamps.
    but i use wima all the time in amps. because of the size. they are perfect for replacing those pesky electros/tantalums in the signal-path. atleast up to 10uf.
    i did try some different caps in a cdp (output coupling) long ago. and i did like roe mkt/mkc best, wima came pretty low on my list :)
    mkp caps were pretty nice too...but they are even bigger
  18. Dingman
    2,536
    Des Moines, Ia
    Ya, space was tight, wima small enough to fit. My mkt's are pretty large.
  19. Dingman
    2,536
    Des Moines, Ia
    I see good things about this amp. And bad things.
    Bad things: Crappy solder joints.
    LOL, tested camera with a magnifying lens to see if I could get SUPER close. Nope, looks like camera auto-focuses to... whatever. 2nd pic is just came, no stupid lens. Turned on "flower" mode or some funny girlie name like that and it got way close! Nice!
  20. Dingman
    2,536
    Des Moines, Ia
    Good golly, the glue.
