mpr2000
I'm assessing a Kenwood KA-5002 integrated amp before I do a full restore (spend money). It arrived in non-working condition, and that consists of not coming out of protect. I went though and checked all the usual things; power supply voltages, amp board issues, did a quick ESR of the caps in circuit, checked for critical resistor values, etc. All okay. IE, I can set the bias and so on per the service manual. Idle current is correct at 30mA (14.1mV across the emitter resistors) and the DC offset is about 10mV on both channels (testing points before the relay). So for all intents and purposes, the amp section seems to be working.
However, it will not go out of protect. So I then attacked the protection board (a separate board from the amp board on this revision of the amp).
Pins 1 (unmarked below), 2, 3 and 4 which should be zero volts, start out at about 100mV and drop to about 30mV each with respect to ground after about 3 minutes. So I'm imaging that is why it won't go out of protect.
I did pull the output transistors and they test good for gain and leakage. Transistors on the amp board were checked for gain in circuit.
Anyway, any thoughts on this? Leaky transistors before the outputs? Pins 1 & 3 on the protection board is connected to the output emitters for one side, and pins 2 & 4 connected to the output emitters the other side.
One thing I'll mention, this amp seems to be a low serial number (411386) and the service manual is close but not exact. IE, my amp board is an X07-1020-00, where the service manual shows X07-1020-01, etc.
And from that come a couple of oddities; the relay coil is connected (as found) to pins 7 & 10 below. The manual shows the coil connected to pins 6 & 7 of the protection board. And pin 9 on mine is not connected to anything - and does not appear to ever have been. So - how would the relay coil ever work connected to pins 7 & 10?
I traced out the protection board and mine does match the manual here.
