eizner23
Super Member
Pulled the KA-5500 onto the bench, problem was distorted output, protection engages when pushing the unit. Bulb tester was dim. The relay engages ( but slowly) and powers up.
Bias was a little high, left channel 110mv right 72mv. Checking differentials, I see they are underpowered.
Looking at schematic and checking test points I find B+ rail in power amp is underpowered, reading -30v, should be -44v
Tracing upstream to power supply, I am only getting 30v to pin 8, should be 44v
Pin 5 is -31v, should be -44v. Pin 11 reads - 19v should be -24v. Pin 9 reads 20v should be 24v
Between dk2 and rk1 I only get 22v. Between pin 4&6 I read 26vac, should be 32vac.
Are these symptoms of a defective rectifier? Would that cause the bulb to shine dimly? Thanks for any input.
