mikepick
I got a Kenwood Ka-7100 from the Auction Site for a reasonable price, took a bit of a chance on a cheaper unit that was of unknown functional condition but looked cosmetically ok. Been interested in a higher-power unit since my KA-3500 recap, I like this era of Kenwood.
It was delivered this week, and it seems like its functionally in good shape. I tested it on a dim bulb, and once that passed, I tried headphones, tested DC offset, and finally speakers with a source in AUX.
It's got dirty pots, switches, and connectors, so it took some fiddling to get it going, but I finally got it sounding pretty good through a pair of Smaller Advents.
Yesterday I had a chance to take it apart and inspect it further. I had been reading some of the many threads on 7100 repair here and was prepared to look for a few things. Sure enough, it had suspect looking joints under the middle foam piece around Q34 / C41 / R84 / R85. I cleaned those up and resoldered them, and am trying placing the foam support farther forward so it doesn't sit below those joints but on the edge of the board.
I found two issues in the inspection:
+ one of the plastic corner supports on the back of the case is broken. Not a big deal, I think I will remove these anyway when I eventually make a wooden case for it.
+ more seriously, the volume pot shaft is broken. There was a fair amount of slop in the volume know initially, which I chalked up to loose set screws, but I don't think I am going to get a tight fit on the know without figuring out a repair or replacement of the volume pot.
The plan, I think, is to recap it, put new micas and grease on the outputs, and try some of the heat mitigation ideas others have tried, such as heatsinks on Q31 / Q32.
