Kenwood KA-9100 Wood Case
Discussion in 'Kenwood-Trio/Kensonic-Accuphase' started by punprankster, Dec 3, 2017.
  1. punprankster
    punprankster AK Subscriber Subscriber
    811
    New jersey
    I have a wood case from a KA-7100 that I want to use on my KA-9100. My only concern is that it doesn't have the side vents that the stock wood case of the Kenwood KA-9100 has and that it might cause the 9100 to overheat. Has anyone tried using something similar or does anyone have any advice if this is feasible?
    Thanks!
  2. oldboats
    oldboats AK Subscriber Subscriber
    101
    Fargo, North Dakota
    Just ship me the case and you will no longer have this concern.
    Sorry, I do not have any real help.
    Bump for someone who might know.
    punprankster likes this.
  3. Blue Shadow
    Blue Shadow I gotta get me a new title
    18,790
    SE PA
    The power amps on the 9100 are on the sides. The 7100 has a u-channel of heat sink through the middle of the amp. Air enters from below the 7100 and exits the top of the unit. I would think the cabinet is setup to allow this with an open bottom.
    If you use this cabinet on the 9100 it will run hotter than it should to the point of being unhappy if you crank it. You should have some side vents installed in the cabinet to use it with this amp. Not hard cut some holes and install a chunk of metal screen of choice.
  4. punprankster
    811
    New jersey
    Thanks Blue Shadow. I'd hate to mess up the 9100. I'd really want to house it in a wood case in the one I have now as buying a separate wood case is too costly.
  5. JG777
    JG777 New Member
    35
    Sure u could buy the one I have coming, don't want or need the wood box, to me it just holds in heat. It will need restored.
  6. punprankster
    811
    New jersey
    How bad is it that it needs to be restored? And how much would you be willing to part with it?
    Thanks!
  7. JG777
    JG777 New Member
    35
    Its got a lot of heavy scratches, its all intact, a couple of chips on the corners. I am going to sand it down & see how it looks, its ugly as it is now, the kid or guy I bought this amp from on ebay ripped me off, said it was "from a working environment" all he knew was that the "lights came on" when he flipped the power switch, its got a fried left channel & probably other issues, not happy. I dont know how much it is worth but as is its just ugly, I'll let u know.
  8. punprankster
    811
    New jersey
    Thanks. I would appreciate that.
