Hi everyone. Hope this finds you well.
Next up is a Kenwood KR-5030. The machine seemed like it could be suffering from classic 'power-switch-eye-tis'. That is not what's wrong -- I think -- now that I've begun to take a peak.
(EDIT: We shall find I was mistaken. Power switch failure IS exactly what was wrong.)
I've cleaned up the contacts in the power switch. There definately was a good bit of carbon build up on the contacts and a little arc residue on the interior switch housing. Also cleaned mains fuse holders and fuses.
Still fizzling horribly. Dial lamps flickering like mad. Good news is, we are getting enough juice to activate the relay. But I'm afraid to leave the receiver turned on for very long. Fizzling sound sounds like it is coming from vicinity of the power supply slash transformer area.
What do I have here; a bad safety cap Ck1 0.01uF 125V? Other possibilities that should be dogged down? Recommended next steps; test(s); substitution component(s); cautions?
After I fix what's wrong with it I DO plan on doing thyristor / power-switch-modification, AND a restore, assuming nothing so major it should be parted out.
Thanks!
Thanks!
