Kenwood KR-6600 Stereo issue
Discussion in 'Kenwood-Trio/Kensonic-Accuphase' started by jkcoondog3, Jan 22, 2017.
  1. jkcoondog3
    jkcoondog3 Active Member
    275
    I have an unexplained issue. Left channel does not work in stereo mode when tape selector is set to source, which is straight up. Both channels do work in mono. Both channels work fine in stereo if I have the tape selector set to source mon. Whats up with that. Everything use to work fine on tape source, but recently left channel no workie in stereo. I have done a complete de-oxit job but nothing has changed. Like I said, works fine set to source mon.
  2. JRC75
    JRC75 Active Member
    143
    Easton, Pa
    Try input a source maybe AUX to left side only. Gently move switches slowly one at a time and see if you get signal through. Could be Deoxit did not get to sweet spot of contacts. Or maybe another problem.
  3. jkcoondog3
    275
    I tried all that and nothing. I did find out that if I turn up volume loud enough I can hear left channel
  4. JRC75
    JRC75 Active Member
    143
    Easton, Pa
    I would remove power get an ohm meter and look at the switch contacts. Does it have a pre amp out and main amp in on back?
  5. JRC75
    JRC75 Active Member
    143
    Easton, Pa
    If so turn power off plug into main in with a deck with variable output (this would become the volume control that's why you have power off). and see if both channels work. If both channels work problem is in pre amp section. Turn off power before removing signal to main in.
  6. JRC75
    JRC75 Active Member
    143
    Easton, Pa
    Think I led you a bit astray jkcoondog3. Had to go help a friend mount a TV. Your problem has to be in the pre amp section and could be in the switches, loose connection, bad component.
  7. sregor
    3,647
    Mass
    What is plugged into the tape inputs and outputs- especially tape B, As far as I can tell, the only difference between source and source monitor is the tape output from A is sent to B, instead of B connected to the source Not sure what A input is. Else problem points to S2 (tape monitor switch)
  8. jkcoondog3
    275
    Well guys I think. No I know I fixed the problem. I put it back on the operating table, removed face plate and held receiver up on its back and did a de-oxit through the mono, stereo switch and let gravity take the deoxit into the control and walla that was the problem. Amazing how 1 switch, regardless of which 1 switch can cause problems. Thanks for all the help. I guess I hit the sweet spot .
  9. Scottansi
    Scottansi New Member
    1
    I just acquired a 6600 and had the exact issue! Your solution fixed it 100%! Thanks for posting this!
