'bout 3 christmases ago. Finally got to it, no sound from speakers, some sound from headphones.
Taking it apart, I found that it got a bug...something that crawled inside and made a cocoon under the R55/R56 resistors for the headphones hatched in the warm (this was in my garage as a daily driver for over a year) and it splorched one of the resistors. one reads the spec 330, the other now half at 160. Right side, and coincidently, the right side has a slight distortion. Since kenwood placed these resistors exactly on the drive output, Mr Bug got full output current.
He didnt survive.
Anyways, this has a simple protection circuit described in the SM as 'ASO' (avoid senseless overload?) on page 11 of the SM (my copy from Rick in hand, or here at the AK or on HFE.
I figure some stuff is hurt - or not - so am building a BOM for the 4070. probing around, I note that neither emitter resistor for the outputs has any flow on it (spec 15mv). The ASO circuit is to detect over voltage on the emitters of the NPN outputs and turns on or off a cascade of stuff such that it eventually grounds out via Q23 the power supply if the input pairs. It would seem to me that as soon as overcurrent quit, it would turn back on, at any rate, I have no current. I have no reason to believe that any outputs have any current thru them other than the faint signal I heard.
I have not started taking apart the amp yet as I am getting my order list ready, I have just about everything BUT, Q21 is listed as a 2SA750(1) (e) or (f) suffix, or a 2SA872 (D) or (e) or 2sa893 (d) or (e)
Im not finding realistic subs for them. 2SA970 has been mentioned in the past but mouser no digikey appear to have.
One AK post from years back, for a KR 7300 list the KSA992 as a sub - in the audio path, this is not, its the protections. However, I have read that the 2SA750 (e) or (f) is a very high 350-700 hfe and other subs like 1815s etc are no high enough.
Any recommendations?
It could be that the ASO circuit got torched and now Q23 is always on, I guess a simple test would be remove it, and if music comes back, voila, BUT, if something else downstream is bad, I risk really blowing the crap out of what is there...
Sadly, not everything is cut and dried in here, for some unknown reason designed to aggravate me, half the amps resistors are made out of carbon deposits on the board, kinda hard to lift those legs...
He didnt survive.
