kenwoodm2a
Member
So I started checking the alignment of my Kenwwod KT-3300D tuner.
I'm practicing on my spare unit first to make sure everything goes ok and I have marked off all pots and coils with a sharpie just to make sure.
For the most part, everything so far is going good and I can see actual changes in my adjustments on the scope, distortion meter and ac/dc meter.
On the alignment sheet that I attached to this post, items 5, 6, and 7 are causing me some grief as I can't seem to notice any changes on my scope when making adjustments which is leading me to think that perhaps I'm doing something wrong.
Attached is a picture of my scope display showing the 1 kHz output at the RCA outs as per the alignment procedure.
Can anybody explain why any changes to the coils are not affecting my output reading?
One thing I will mention is that on the 3rd attached alignment page, it shows a picture of a 300 to 75 ohm antenna adapter and what they call a dummy antenna. I'm not sure what a dummy antenna is but what I did is I gutted the 300 to 75 ohm adapter and connected the center pin direct to one of the screws and the outer ground shield direct to the other screw which is connected to a 50 to 75 ohm resistive pad to the generator. I assume that would be the correct way to do this?
Thanks!
Thanks!
