Kenwood KT-5500
Discussion in 'Tuners' started by charles64, Oct 20, 2009.
  1. charles64
    charles64 reVox reGret
    1,485
    The Ocean State
    Picked up this simple,though well made looking vintage tuner. Does anybody know about this Kenwood KT-5500? Haven't had the chance to check it out yet but I know Kenwood has a loyal following around here. (Pic's later)
  2. Urizen
    Urizen Lunatic Member
    24,636
  3. thedelihaus
    thedelihaus Nocturnal transmissions
    29,301
    Boston Area, Massachusetts
    I owned one. A nice performer.
    The 7500 is a great performer easily modified for fantastic performance.
  4. aileenamegan
    aileenamegan Super Member
    1,807
    Germany, Frankfurt area
    In fact a fine tuner for beginners. Better than his competitors at that time. Brother - with gun metallic front - is the KT5550.
    Smallest one is the KT5300.
    The series continues with KT6500/KT6550, KT 7500/7550, KT 8500/KT8550.
  5. Old_Tech
    Old_Tech Yer-isn't!
    3,903
    Its a nice tuner Kenwood had several top performers in that series.
  6. aileenamegan
    1,807
    In fact, I have most of them - except the KT917.
  7. DoctorLondom
    DoctorLondom New Member
    2
    I have a KT-5500 and I figured this may be a good place to ask rather than starting a new thread.
    When I first got it, it worked fine, every aspect. However, recently it will only receive FM in mono and the "stereo" light never illuminates, even with the signal strength maxed out.
    I find that there are certain spots on the tuning where it will illuminate briefly. However, there are no stations or any type of signal at these spots!
    I am guessing some type of alignment or calibration inside is out of spec. What would you all recommend I do to remedy this? I consider myself competent with electronics but I do not have any special tuning equipment that I have been reading about here.
  8. Splatter Pak
    Splatter Pak High-End Scrounger
    3,934
    Independence, MO
    I have a KT-5500, and am not too impressed with it. I have been enjoying the superb tuner in my Luxman receiver.
  9. DoctorLondom
    2
    Just replying to say I've fixed my issue. I tweaked the rightmost trimpot on the PCB and immediately the FM Stereo light illuminated. It was just dirty. I'm sure some Deoxit would have done the job just as well.
    8xlaxx likes this.
  10. yardanimal
    yardanimal Active Member
    323
    inland so cal desert
    If you are still there, thank you doctor london. It worked for me. Contact cleaner on the rightmost trimpot was not enough, it had to be tweaked.
  11. bernouski
    bernouski Active Member
    142
    hello all i just purchased a Kt5500 on ebay for $35 bucks and its in great condition.
    i was wondering if the modification list on this link is optimal to make this tuner compete with the big dogs.
    http://www.fmtunerinfo.com/DIY.html
    i have my vintage stereo repair guy on the job as we speak.
  12. 8xlaxx
    8xlaxx It's all ball bearings nowadays. Subscriber
    4,696
    N-Va. Beltway Outlier
    Reviving this old thread,...
    Which pot are you referrring to that you cleaned and tweaked? A recently purchased KT-5500 that I have is showing the same symptoms.
    Thank you.
    :needpics:
  13. Audiokingman
    Audiokingman Active Member
    226
    Near Pittsburgh, PA
    Which is the "rightmost trimpot"??
    Is it the one my pencil is pointing to?
    UPDATE: I tapped the variable resistor trim pot that I'm pointing to with the tip of my pencil a few times, and now the stereo light comes on properly and all is great!
