Hi all,
My 2 Trio KA-9300 aka Kenwood model 600 have issues with very loud crackling sound therefore i tried to replace the 2. differential transitor pair Qe1/Qe2 2SC1400U with ZXT694B( modified the pin layout C-B-E to E-C-B) in the Power amps metal box and Qe5 2SC1681(GR) with KSC945C(modified pin layout) , then i powered it up with DBT 100W the lamp gets bright, so i measured the voltage rails of both channels with the result B+/- 26V, even without Power supply B.
It means i have some shorts i must find out and solve.
OK i first take out two pairs of 2SA747A/2SC1116A of the left power amp channel then measure again the voltage rails (still with DBT) i still get B+/- 26V on both power amp channels.
Further i take out also other two pair 2SA747A/2SC1116A of the right power amp channel, now the relay clicks and i get the readings B+/- of both channel 56,4V.
If i as trying re-install the two pair 2SA747A/2SC1116A to the left power amp channel , i get B+/- 26V on the left power amp channel again, but to me i can not explain myself why i also get B+/- 26V on the right power amp channel without any power transsitors 2SA747A/2SC1116A installed while this amp is designed with Dual power supply? How can it be?
In addition i have checked all wirings, transitors, diode, resitors, their orientation etc on the both power amps and do not find any mistake i may make.
Could someone help me pointing out the possible causes of such issue as that problem occur the same issues on the both amps.
Thank you
Thank you
