Justgotohm
Super Member
This is by no means a score but I found a couple lonely speakers at GW for $10. One being a Altec 201 which had an attractive cabinet that I will use for a small home sub, the rest of it was junk. The other was this KLH 150 that by appearance I assumed would be a very cheaply made JC Pennish speaker. I took it because it was a set for $10 and may have a $5 coil in it I could use. Well I tore into it and found a pretty complex crossover, the mid has a huge magnate with its own enclosure and seems to be well made, the woofer was a replacement dual voice coil from another source. The cab itself had foam on three sides with polyfill as well as a screen over the port. I'm curious now since KLH seemed to put a lot more into this speaker than your average off the shelf speakers from the same era. Just wanted to share.
