plbeard
Just a tip for those looking for decent, acoustically transparent, fairly historically-accurate-looking grille cloth for KLH 5s, esp., but potentially for others, too: this is 18ct thread, like the originals. It is polyester and is currently less than seven dollars per bolt yard--more than enough for two speakers (56" x 36"). Search for
"VLN326 Khaki Polyester Linen." ("Real" linen may go at six times that price.)
These are KLH 5s with all correct components and rebuilt crossovers that I cobbled together from parts.
Note this same cloth comes in other shades too. This cloth also is visually non-translucent so it doesn't show cavity shadows as some fabrics thin enough to be acoustically transparent do.
You can find real acoustic research on thread counts--and while this is a great service, I would qualify that research to note that each type of fabric is idiosyncratic. 18 thread count/ inch is generally a good bet. Research may claim that 14ct thread is Ok, and I have used 14 ct Aida embroidery cloth on some Dynaco 25s to good effect, too, but a recent experiment with a different brand of 14ct cloth showed that that brand was not acoustically transparent because of the thickness of that brand cloth's thread. I recommend doing your own tests with white and pink noise--it will be pretty obvious if the cloth attenuates high frequencies or not. I have found some great looking cloth at 28ct or slightly above and at those thread counts--even though the cloth looks visually transparent when held up to light--the linen occludes high frequencies too much.
