given the cost of the upgraded parts I would say that is a good (Canadian Dollars) deal which I would take especially for a mint pair. I would also recommend that you remove the dated looking factory riser and place them up on 14 -16 inch tall four post stands will depend upon your height and seating. You want to place the centre of the mid horn at your seated ear level. See Skylan Stands for good image. I have also attached a photo of a Harbeth on a similar size stand to give you an idea of the visual. Weight simply mounts to the centre of the inside of the passive radiator use minimal adhesive three or four very small dots of glue is all you need.
Thanks very much for the info Sir Moray!
I know Noel Nolan from Skylan Stands in Alberta, ordered from him these similar excellent stands a few years ago. Filled them with dried sand. He gave me one of his invention: 8 ''Q Discs'' to place under each spkrs (4 discs per spkrs), a very nice improvements.
I am also thinking to make heavy one pillar stands with concrete patio tiles...
I have been able to find pics of your bracings posted by other members, it's pretty clear, just need a couple or dz hours...
What I can't find is pics of your 2.5 oz weights (steel washers ot lead soldering wire?) installed in the passive radiator...I'm very visual.
BTW I can also put my hands on less minty Chorus 1 for Canadian $650 as well. Are they much better than the Quartets? I have a 20'x20' carpeted listening room in my basement and intend to run the Quartets (and/or Chorus 1...) with a 50W Audio Research integrated tube amp. I usually don't listen to loud levels.
I have owned at least 25 pairs of mid to high end speakers (JBL, B&W, Spendor, Kef, ProAc, Tannoy, Dynaudio, Dynaco, PMC, Paradigm, Energy, Mission, Martin Logan, Altec Lansing, Harbeth and many others...). Also did DIY beauties with Scanspeak and SEAS drivers, those I kept along with the Proacs. Ears are always the final judge but, as my wife says, my quest for Audio nirvana is not over yet at 57 YO...
Any pics of where you have intalled the weights would be appreciated. I think the Quartet passive rads are the KD-13
Cheers from Montreal
Antoine
