ringading
Well-Known Member
Picked up a 7400 at the local thrift - a miracle in itself as they usually send these off to fleabay.
It was working well and I replaced the capacitors on the main amplifier board and gave it a once over with DeOxit. On adjusting the board for screwing it back into the brackets, one of the legs on a transistor just snapped off. I assume that it was brittle due to the heat this particular model puts off. It was the 2SA620 on the right side of the amplifier board. Replaced it along with its counterpart on the same side with a KSA992 (Qe1 and Qe3).
Now I very little sound on the right channel. Not sure what is going on. I was going to start pulling the transistors to test starting with the outputs and working my way back with the drivers. However, I assumed that since the new transistors were on the right side of the board that they would be the right channel. However, looking at the schematic, I am not sure. I am still learning to read schematics but it would appear that odd numbered components are actually for the left channel and the even are for the right channel - even though on the board the odd are on the right and even on the left.
Can anyone confirm that even # are right and odd # are left? With the replacement of Qe1 and 3 I assumed that perhaps they were incorrect or something else is bad on that side.
