KR-8010 - 2nd Take
Discussion in 'Kenwood-Trio/Kensonic-Accuphase' started by Super Noob, Nov 18, 2018.
  1. Super Noob
    Super Noob AK Subscriber Subscriber
    326
    Fort Myers, FL
    Was so impressed with my KR-8010 that I am going to do another. Will likely be sold on Barter Town once it is completed.
    Will update the post in the upcoming weeks.
    HopJohn... Kenwood Guru = what is your opinion of this model. It is a beast.
  2. Super Noob
    326
    Fort Myers, FL
    Unit Arrive Updates to Follow.
  3. BigElCat
    BigElCat Mmm Hmm Subscriber
    8,112
    South of Kansas City
    I had one of those...luv'd it.
    Mine had the factory side handles.
    Massive.
    Super Noob likes this.
  4. Super Noob
    326
    Fort Myers, FL
    Power Switch - Contacts Switched To Unused Side and TRAIC Modification Complete.
    Prior To Disassembly
    In Process
    Finished - Works Flawlessly
  5. Super Noob
    326
    Fort Myers, FL
    Power Supply:
    Before
    After:
    Replaced Caps & Relay:
  6. Super Noob
    326
    Fort Myers, FL
    AMP Boards:
    Before:
    After:
    Parts:
    Trim Resistors (Bais) Replaced with Bourns 25 Turn Sealed VRs.
  7. Super Noob
    326
    Fort Myers, FL
    Outputs:
    Outputs Pulled, Cleaned, Re-Pasted with Wakefield Thermal Paste.
  8. Super Noob
    326
    Fort Myers, FL
    PreAmp Board:
    Before
    After:
  9. Super Noob
    326
    Fort Myers, FL
    Front End Boards / Tone Controls:
    Before
    After:
    Also DeOxit All The Controls / Contacts.
  10. Super Noob
    326
    Fort Myers, FL
    Tuner Board:
    Before
    After:
    Parts:
    Spent 2 hours cleaning the old flux off the circuit side with 90% Alcohol.
    rickl likes this.
  11. Super Noob
    326
    Fort Myers, FL
    Filter Caps:
    Upsized the caps from 18000uF to 22000uF 105 C, 80V Snap In Chemicon. The solder tab direct replacement is not available, so I elected to remove the tabs, install them on new caps, stuffed them in the old cap cans, and reinstalled using the original bracket. Turned out sweet.
    Install with 2.2 uF Stacked Film
  12. Super Noob
    326
    Fort Myers, FL
    Adjustment:
    The left channel offset was roughly 40 mV.
    The right channel offset was less than 5mV.
    40mV is okay... but not up to my expectations. I elected to pull out the 1st different pair:
    Replaced A921s replaced with A992s perfectly matched.
    Offset Improved:
    Right
    Left:
    Bias Dialed Up To 50mV:
    rickl likes this.
  13. Super Noob
    326
    Fort Myers, FL
  14. Super Noob
    326
    Fort Myers, FL
    Here are finished pics:
    The case shell paint was dull. Hit it with hammer black finish. Turned out really good.
    Used all 105 C high quality Nichicon Caps (mostly KA series) and WIMA films.
    106 New Caps
    2 New VR Sealed Trim Resistors
    2 Gain Match SA992 Transistors
    New Relay
    9 New LEDs
    Here is a list = hope it helps out someone in the future.
    https://drive.google.com/file/d/1vR64nceIHzzPqHsHg76uJI3KkVbQqB_-/view?usp=drive_open
    Sounds as expected clear and strong. Will run in for a few weeks and list on barter town.
    gort69 likes this.
  15. Super Noob
    326
    Fort Myers, FL
    I was so impressed with my 1st one... that I wanted to do another.
