JacTaylor
On the lam
I have been overzealous in my rebuild. I had successfully performed the service bulletin, replaced caps and matched qe1 and qe2. Everything was working then one day the speaker relay wouldn't kick in. Took a look and it had one contact fused. So I replaced the relay and the caps while in the power supply. Still it wouldn't click in. I measured pin 4 and 15 on the amps and one was at 60.5v and the other was around 84.7v. I took the 84.7v amp out and tried just the one 60.5v amp and the speaker relay clicked in.
I took both of them out and looked closely at any differences and I found where qe3 pin was loose on the 84.7v, probably from trying to remove the cap next to it and never soldered it back. Soldered that in and speaker relay kicked in with both amps in. I set the bias for both at 50mV.
However, now I have a loud hum independent of aux, phono, fm am setting with the volume down all the way. Did I do that by testing with just one amp board in? I must have blown something, in the power supply???
