Anybody ever hear one of these things? They use 4 KT88's per channel and supposebly put out 100wpc.
http://www.caryaudio.com/reviews/may97.shtml
A good job, maybe, but you say nothing hard about a GREAT JOB without asymmetric and/or freq-dependent distortions, or bandwidth limitations (transformers), steady over time?Originally posted by NOSValves
Nothing hard about doing a phase splitter that does a great job.
Your falling for the tube lore here. Lets compare THD numbers watt for watt of output of your SET amp to my Push Pull [snip]
Originally posted by tubino
If by "tube lore" you mean the engineering textbooks of the 40s and 50s, then yeah, I fell for it.
THD is not the figure of merit here. I don't have time at the moment to do this right -- I'll try to come back to it. Tweaking to balance the AC signal is not just a one-time thing, is it? Which do you pick as a great phase inverter?
BTW, I still happily listen to PP amps. I'm just a bit happier with a fine SET. Maybe that's the difference between good and great?
Craig,Originally posted by NOSValves
reading information from the 40's and 50's is a pretty narrow way to garnish a complete opinion. Your leaving out the hay day of tube Hi Fi. Oh and by the way during the hay day of tube Hi Fi the late 50' and 60' almost no manufacturer even made a SET amplifier. hmmmm wonder why?
