KX200, Screw size for plastic feet?
Discussion in 'Fisher' started by escorial, Dec 5, 2018.
  1. escorial
    escorial AK Subscriber Subscriber
    166
    Anyone know the machine screw size for the 4 plastic feet?
    TIA
  2. bhamham
    bhamham AK Subscriber Subscriber
    2,077
    Austin
    I'm pretty sure they're a #8, but careful on length - you don't want them poking up too high
  3. escorial
    166
    Thanks ':)
  4. audmod01
    audmod01 Super Member
    1,382
    Tioga, TX
    To be accurate they are 8-32 machine screws. Depending on the height of the feet, choose a screw length that is just enough to go into the captive nuts on the inside of the chassis bottom cover. Don't get screws that will go a long way into the chassis as you might wind up shorting something out.
    Joe
  5. bhamham
    2,077
    Austin
    Sorry for not being accurate, escorial. Joe has it right 8-32 and not too long.
    Bruce
  6. notdigital
    notdigital AK Subscriber Subscriber
    2,287
    NYNY
  7. larryderouin
    22,203
    Glen Burnie Md.
    You can always get a little longer, install the feet on the plate then leave a 1/8" stub, by using a dremel with a cutoff wheel. I usually get 1-1/4" length and cut them off due to differences in foot size.
  8. fred soop
    fred soop Super Member
    2,101
    If the screws are a bit long, you can also pad them with washers under the bottom plate. This will have the advantage of making the unit sit slightly higher, increasing air space underneath.
